BMR Tech
12-15-2011, 03:54 PM
BMR Suspension
Adjustable Lower Control Arms for the 2010+ Camaro and Pontiac G8
Increase rear camber adjustability, reduce suspension deflection, and maximize rear cornering stability with a set of Adjustable Lower Control Arms from BMR Suspension. Superior to the factory stamped steel arm, the BMR Control Arms are constructed from heavy duty 2” square tubing and internally-gusseted laser-cut mounting plates. The BMR Adjustable Lower Control Arms (TCA029) feature low-deflection polyurethane bushings, reinforced sway bar mounts, and massive 1-1/8” CNC machined double adjusters to provide maximum camber adjustment for lowered vehicles. Installation time is only 3-4 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com (http://www.bmrsuspension.com/), email sales@bmrsuspension.com (sales@bmrsuspension.com), or contact them at BMR Suspension, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
http://www.bmrsuspension.com/siteart/products/TCA029_image1_large.jpg
