62-65 nova LS1 swap fuel tank
Category: Engine - Intake/Fuel
Price: $850
Location (State): IL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Non-LS Part
The tank has been modified to fit two walbro 255 fuel pumps inside. This is capable of flowing enough fuel for 1000 horsepower. The fuel pumps are included and have less than 100 miles on them. The fuel sender has been modified and uses two -8 feeds (one from each pump) to feed a yblock that has one -10 out (main feed). The fuel sender also includes a port for one -8 return. I did have to modify my trunk pan so the fittings would clear. You could also shim the tank down if you wanted to do that.
I will include everything needed up to the -10 main feed line. Tank also comes with a fuel level sender.
$900 and I will include the shipping. New this setup is roughly $1500.00 and I am not including any of the custom work to make it all fit.
Shoot me an email and I will get you pictures. There is nothing wrong with the tank and it works great. I am changing fuel system setups and need to get rid of this. I am putting a cell in the trunk and no longer need the fuel tank. It is in excellent condition and works flawlessly.
Again, shoot me an email address and I will get you some pictures.
Thanks.
Thanks.
