There will be a casting number on the cylinder head that will tell you for sure. My guess is you have a set of 853 casting cylinder heads being that your car is a 99.
hmm yeap they are the 853. Im used to old SBC not these LS1 so are they **** heads? I know they arent as good as aftermarket(obviously) but how much better are the 241? would they be worth the effort for a budget upgrade?
The only difference from 853's is they a cast differently. Same ports...
243's in stock form are worth 15 or so over any LS1 head...
you can get 241s heads for $100,243s for $400.check the valve seats for leaks .I would get the 243s if you can ,with the right cam you can make 425+rwhp.
