LS1 with 194k miles
Old 12-16-2011, 07:42 PM
kjcmusic17's Avatar
Default LS1 with 194k miles
My Firebird was rearended a couple weeks ago and deemed "totalled." I took this as an opportunity to get an LS1 equipped car. I found a 98 TA with 194k miles on it. What should I be concerned about with such high mileage?
Old 12-16-2011, 07:46 PM
projectX's Avatar
Valve train should be re done.
Old 12-16-2011, 07:52 PM
kjcmusic17's Avatar
how much would that run me?
Old 12-16-2011, 08:14 PM
Gordon0652's Avatar
That's a lot of miles...
Old 12-16-2011, 08:28 PM
BlumaroZ28's Avatar
if the previous owner took good care of it , oil changes and other maintanence, and did not beat the holy hell out of it, then you probably wont have any problems, if you leave the engine stock. i am a drivability tech in the detroit area and see a lot of lsx engines. many of them get well over 200,000 miles, some even over 300,000. (usually in the trucks). however, if you start to mod the engine then you could drastically decrease the lifespan of the motor. either way i would recomend doing a tune-up (if it hasnt been done in a while) and defintitly some kind of a fuel and intake system cleaning. not the crap in the bottle on the shelf at the local parts store but a professional system. i have used BG Products with great results. try to find a local shop that uses it, or what ever is common in your area shouldn't cost any more than 100 -150 for the cleaning. do the tune up youself not as bad as it loooks.
Old 12-16-2011, 09:55 PM
kjcmusic17's Avatar
Thanks for the insight! A friend said that a compression check will reveal a lot.
Old 12-17-2011, 01:37 AM
777Shock777's Avatar
I would also say completely swap all the fluids,, always gotta play it like the previous owner is lying to you about everything
Old 12-17-2011, 06:20 AM
garygnu's Avatar
check the engine for piston ring blow by.hold your hand over the oil filler tube,if you feel pressure you have some blow by.if you buy the car consider a valve train pkg from Texas Speed.also consider getting a new timing chain and a oil pump ,and rebuilt rocker arms.
Old 12-18-2011, 09:36 AM
kjcmusic17's Avatar
I figured I would need a timing chain. What's the price estimate on the other items? Is that something I can do myself?
Old 12-18-2011, 10:12 AM
garygnu's Avatar
go to Texas speed for most of your parts.you can go to ls1howto.com for good instructions on doing most of the work your shelf.or you could locate a engine with lower miles like 6.0.
Old 12-18-2011, 12:45 PM
kjcmusic17's Avatar
I would love a 6.0 but I don't have the money for that haha. That's why I'm looking at a car with almost 200k miles
