Doing heads and cam on 100k+ motor?
Old 12-17-2011, 11:03 AM
senicalj4579's Avatar
Default Doing heads and cam on 100k+ motor?
Heads and cam are in my thoughts for the car. Motor has 105k. Whats your thoughts on doing heads and cam on a higher mileage motor?
Old 12-17-2011, 11:06 AM
Ronny_02_WS6's Avatar
It will be fine as long as you upgrade the hole valvetrain: pushrods, valvesprings, lifters, timing chain etc.
Old 12-17-2011, 05:50 PM
3rdCoastPowerSports's Avatar
105k no problem. I have done it before with no issues. need some new things though as stated in the post above. I would say if you are really paranoid about it you could run a leak down and compression test just to be sure you don' have any blown rings and such...
Old 12-17-2011, 05:53 PM
Turd Gen Guy
1nasty86's Avatar
243's and a custom cam and rock out. i like the eps 226/234... but thats just me..
Old 12-18-2011, 01:50 PM
Thanks guys. Is 450+rwh through a stalled auto out of the question?
Old 12-18-2011, 04:18 PM
BirdsSince16's Avatar
With heads and cam it's very possible.
Old 12-18-2011, 05:04 PM
peterlawl84's Avatar
I did my H&C at around 107k, ended up needing to rebuild the trans and getting a new rear within a couple months (blew both)...just something to think about in addition to the supporting mods already mentioned.
Old 12-18-2011, 07:05 PM
uLs1a's Avatar
Did my heads/cam swap at 112k and almost at 118k now with no problems.
Old 12-19-2011, 08:50 AM
BRDMAN's Avatar
just do the supporting mods and you be good.
Old 12-19-2011, 09:03 AM
Rare96LT1Formula's Avatar
+1
Also grab a ported/high volume oil pump and some new lifters imo.
Old 12-19-2011, 11:27 AM
IRONFIST's Avatar
Should be very possible, but keep in mind that even though your engine will make that kind of power, your tranny and rear end ( which have a lot of miles on them ) are likely going to wear out and go a lot faster then if the car was stock.
Also, I noticed that with my build, ( I have about 97000 miles ) my car made about ten less hp then I expected... might be due to the mileage.
Old 12-19-2011, 02:05 PM
AiDRocks's Avatar
How much HP are you making if you don't mind me asking? I want to do H/C with my 99 as well.
Old 12-19-2011, 05:25 PM
Thanks for the help guys. Iv been looking at options and looks like the 243s are a good option. Im also interested in having a set CNC'd by Advanced Induction. Says on their website "Typical gains are 40-50rwhp over the as cast 243, with most LS1 & LS2's producing 450-500rwhp SAE with daily drivable cams". Sounds great to me.
I noticed 243s are very common in the for sale section. Would you guys recommend buying them used? And if so, seeing how its recommended I upgrade the whole valvetrain I should buy them totally bare if possible?
Old 12-19-2011, 05:41 PM
Turd Gen Guy
1nasty86's Avatar
Just buy used heads and have new valvesprings installed.
