Western Members CA, AZ, NV, UT, CO, NM, HI
turbo: how to choose spring for wastegate
Old 12-17-2011, 04:28 PM
rhinosarge's Avatar
Default turbo: how to choose spring for wastegate
hey guys.. maybe some of your boosted guys can help me out
my trucks vaccum is at 10..
im running the tial 38mm wg.. what spring should i drop in to get about 10lbs of boost ??
thanks guys
Old 12-18-2011, 01:42 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
thanks guys
what size turbo? wastegate spring depends on the amount of backpressure..
Old 12-18-2011, 02:06 AM
XpEdItIoUs's Avatar
Like Ryne said, "what size turbo?" and motor CI? My exact setup on a stock 346 held 10psi with a 10lbs spring. But when I went bigger CI, I had to upgrade my wastegate to a 46mm because the 38mm could not control boost due to higher back pressure and not being able to flow it out efficiently.
Old 12-18-2011, 02:42 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
generally speaking the wastegate size has no bearing on boost holding capabilties, but if the wastegate is too small or not positioned correctly you will get boost creep on the topend..... the backpressure will force the gate open prematurely resulting in receiving lower boost levels then the waste gate spring suggests.... the wastegate spring rating are a "rule of thumb" system to go by, in a perfect situation a 7 psi spring will yield 7 psi boost... but in alot of single turbo apps with v8's its not uncommon to need a 10+ spring to see 6-7 lbs of boost..... i see it all the time on the dyno.... boost controller is your friend!!
Old 12-18-2011, 03:02 AM
XpEdItIoUs's Avatar
Remember my car would get boost creep on first gear? it would creep up to 18+ psi with a 10lbs spring. I tried lowering the spring to a lower psi spring rate, but still would over boost. I even tried running no spring, still it would create boost. I finally cut out the 38mm and welded a precision 46mm waste gate with a 10lbs spring and got 10 psi with no creep. I don't know if it was a faulty 38mm waste gate, but it was recommended by someone on here with lots of turbo experience that I get rid of the 38mm and go closer to 50mm. He explained that the exhaust was not "flowing" through the smaller wastegate and causing more flow to the turbine causing the turbo to spin faster and creating the boost creep.
Old 12-18-2011, 06:07 PM
rhinosarge's Avatar
i see..
well my backpressure is staying at 10
turbo: .96 a/r and 72 cold side.
what manual boost regulator would you suggest then..
and as for the wastegate its a tial 38mm
Old 12-18-2011, 06:41 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i see..
i think the 38 mm gate is a little small for that turbo, they are normally meant for smaller t3 turbos... is this a t4 turbo? what size turbine wheel? why dont you just give the name of the turbo
Old 12-18-2011, 06:42 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
yeah the 38 mm gate is meant for smaller t3 turbos normally... the 38mm gate was a restriction and couldnt bleed off enough exhaust pressure
Old 12-18-2011, 08:06 PM
rhinosarge's Avatar
cause it has no name on it !! haha.. my boy parted his truck.. i switched mine for his.. my old one is a precicion .68 a/r
ima take some pics.. maybe you guys can figure it out.. it was recently rebuilt.
Old 12-18-2011, 08:27 PM
rhinosarge's Avatar
Old 12-19-2011, 01:33 PM
KILLER-LS1's Avatar
that looks really old, but might be a garrett with that V-band compressor housing
Old 12-19-2011, 01:34 PM
KILLER-LS1's Avatar
measure the inducer and exducer size of the compressor wheel with a digital dial caliper set to mm.
Old 12-19-2011, 01:49 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
judging by the fact you have no idea what the turbo is.... i dont see this build going well lol
Old 12-19-2011, 08:32 PM
rhinosarge's Avatar
its all in the tuning.
Old 12-19-2011, 08:45 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
hmmm..... no its not lol
Old 12-19-2011, 10:56 PM
rhinosarge's Avatar
DING DING..
he said garrett !! after calling him 20x to get him to pick up..
but i still gotta look up what exact model or go get some calipers.. cause he said he cant find the paper w the build specs when he got it rebuilt
Quick Reply: turbo: how to choose spring for wastegate
