have ? about factory wiring? 02 ws6
what i have is a 02 ws6 that is a auto car ,and want it to be t56 ...does the wiring just unplug that went to auto trans???
i assume a different ecm would be needed for the 6 speed ??/
just want to use the wiring i have for the dash, also what about the dash cluster?? thanks 4 ur help
The ECM will be different, in program only, it will be setup for the t-56. However there are some other things you will need to address,, the harness,, the T56 has more plugs than the auto,, It has one for the reverse lockout, speed sensors, etc. Your harness will not have some of those plugs. You need to buy a harness, Used is generally fine,, Or do the research and look into tracking down those wires and pigtails and manually installing them.
Try this out. I used it and my swap went well. Just read the whole thing and make sure you have everything you need and understand everything that needs to happen first.
http://www.gmhightechperformance.com...wap/index.html
