Sponsored by: DashLynx
jittery lights
Old 12-18-2011, 02:05 AM
jacobsoup's Avatar
Default jittery lights
im not sure if this is the rights section but i have been having problems with my headlights bouncing up and down. i have replaced the pivot crank arm on one side which tightened things up a little. then i noticed where the arm connects to the headlight assembly the bushing was worn so i replaced that. could a gear cause this bouncing? i really cant tell where else things are loose. thanks
Old 12-18-2011, 02:12 PM
jacobsoup's Avatar
Anyone?
Old 12-18-2011, 04:42 PM
TORK?'s Avatar
Are they actually loose or do you think they are flickering/fluttering? I had a light flicker over bumps that looked like a bouncing light, and it turned out to be a bad ground.
Old 12-18-2011, 05:09 PM
jacobsoup's Avatar
i can see the headlight move. its not the bulb or lens. its the whole assembly.
Old 12-18-2011, 10:12 PM
dabest09's Avatar
Tighten the screws that hold the headlight to the bucket. My lights flicker a lot especially when braking. Think it's a bad ground?
Old 12-19-2011, 12:07 PM
aquariussuperman's Avatar
Are the 2 plastic tabs broken on the back of the headlight bracket? If so, or if they are not slid onto the bracket, that might be your issue.
Old 12-19-2011, 12:18 PM
HibachiZ28's Avatar
My driver side is loose as well. With the projectors it's very noticeable. I have to look at things this week. Let me know if you resolve your issue.
Old 12-20-2011, 07:17 PM
jacobsoup's Avatar
i will check all that tomorrow. i will see if the tabs resolve the issue. i know the 4 screws are tight for the actual headlight.
Quick Reply: jittery lights
