3 channel backing plates $100
Category: Drivetrain
Price: $100
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NJ
Item Condition: Used
LS Engine?: Fits LS Engine
1 Post
3 channel ABS doesn't have sensors at the rear wheels like the 4 channel does. Just one sensor at the center section. Also, the backing plates don't get pressed onto the housing. You would need a housing with ends like the Strange H1143 ends and the backing plates act as the bearing/axle retainers. They would be laid down on the axle, then the seal/bearings installed on the axle, then you would bolt that backing plates to the housing.
