air to water intercooler setups post up pics!
Old 12-18-2011, 10:06 PM
SUPERMAN_00TA's Avatar
Default air to water intercooler setups post up pics!
I have been searching for picturers of Air to water setups installed on Fbody's. If you could post up pics. Im trying to get some ideas on how to run mine. Thanks
Old 12-18-2011, 10:43 PM
WheelsUp84z's Avatar
theres some in my build thread, link in sig
Old 12-18-2011, 11:25 PM
Bobsmyuncle's Avatar
Here's one I built for a guy. Keeps a/c factory fans, rad, everything.
Thanks
Old 12-18-2011, 11:26 PM
And yes it fits under stock bumper lol
Old 12-18-2011, 11:29 PM
Where is his heat exchanger/radiator?
Old 12-18-2011, 11:53 PM
Right infront of the radiator at a 45* angle. 27"x10" 2"thick double pass 3/4" lines
Old 12-19-2011, 12:09 AM
BigBadWhitey's Avatar
Uploaded with ImageShack.usHope this works.......
Not sure if that placement would work for you in an LS1 but it seems decent in my lt1. Didnt have to hack anything appart to make it fit either. The heat exchanger is in front of the rad.
Old 12-19-2011, 07:04 AM
rotacoupe95's Avatar
Size:  110.7 KBName:  444a0318.jpg
Size:  85.5 KBName:  00ab2cd6.jpg
Size:  102.8 KBName:  2011-08-22182014.jpg
Old 12-19-2011, 10:47 AM
LS1TECH Sponsor
Steve Burger's Avatar
Check the gallery section of our site for my car or search on here in the FI or Drag Racing section for "Burkhart Shop Car".
Old 12-19-2011, 04:49 PM
Default pump
Thanks guys this is helping me out alot..... Is anyone using more than one pump? I want to put my ice box behind my passenger seat. Since the pump is only a pusher I thought I would put an extra one.... Yes or No?
Old 12-19-2011, 09:53 PM
any answers on the pump question
Old 12-19-2011, 10:01 PM
droksformula's Avatar
Two is not needed, just get a quality pump, Rule or Meziere.
Old 12-20-2011, 07:46 AM
LS1TECH Sponsor
No need for 2 pumps. One good in tank pump will be good.
Old 12-22-2011, 11:25 PM
xRelapse13's Avatar
would an A2W set up be practical for street driving?
Old 12-23-2011, 01:24 AM
I_Need_Land's Avatar
absolutely.
enough water capacity and an external heat exchanger.
myself, 5 gal water cell in the hatch area, and a stock removed afco heat exchanger from a ford gt500.
and on track days you can put ice in the tank and get it really cold.
Old 12-23-2011, 06:11 AM
JAX04's Avatar
Originally Posted by I_Need_Land
absolutely.
Whats the dimensions on that heat exchanger?
Old 12-23-2011, 12:24 PM
Sarg's Avatar
A2W is what Porsche uses from the factory on several of their vehicles. They are fine for street and track use. Most of those guys will upgrade and add an additional heat exchanger when they turn things up though.
Old 12-23-2011, 06:26 PM
no idea, sorry.
heres a general idea of its size... the black one..
http://www.timskelton.com/lightning/...ntercooler.htm
Old 12-23-2011, 06:42 PM
The H.O.S.S. I posted above has a 7 gallon capacity. Cruising on the highway, the water temp stays within 10degrees of ambient temp. When we r on the dyno, if the ambient temp is say 60*, at the end of a pull the water only reaches 72-73*. The point is, the water capacity is a very important part. Also placing the return as far as possible away from the pump pickup is a good idea too. On the dyno w 60* water(no ice) at the end of a 2-7k pull, making 1xxxhp, we r at 75* iat.
To sum it up, a2w is a fabulous idea no matter what the situation.
Quick Reply: air to water intercooler setups post up pics!
