PCM/cam sensors/LS2 Throttle body
Old 12-19-2011, 06:15 PM
GNIUS's Avatar
Default PCM/cam sensors/LS2 Throttle body
I am building an LS6 to swap into my Inifiniti G35 and had some questions about the PCM.
I want to upgrade my front cover to an LS2 cover with the cam sensor in the front for easy access and use an LS2 90mm electronic throttle body in this build on a fast 90 or modified LS6 intake. Is this possible? What year or gen PCM will I need to run this setup.
My ls6 block came with the black crank sensor and my car is currently equiped with a drive by wire gas petal. Thats all I got. Most of the stuff I found on this was a little cryptic for me and I was a slightly confused.
Please help with any info.
Thanks!!!
