Shop cleanup! Look i mite have what u need ls parts 4 alot of models!!!!
Category: Accessories
Price: $10
Part Fits: 2010+ Camaro
Location (State): SC
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
ls1 double roller timing set with torrington bearing 75.00
comp cam custom grind ls1 cam 3731/3734 hr114 h8251-06 lift int. .610 ex.615 duration@.050 int. 242 ex.248 114w/2degrees adv. ground in lsa 112 c/l 150.00
317 heads fresh cleaned ,valve job, valve stem seals and surface trued up .005 300.00
new take off ls3 40 pound injectors 65.00
fast 30507-8 50 pound injectors 2k miles 225.00
nib msd blaster 3 coil part#8223 30.00
nib msd dual coil part # 8224 30.00
nib gm accel module part # 35361 30.00
nib jegs lt1 plug wires part#40215 15.00
nib faze 10k rpm tach with shift lite part#88301 70.00
TRAILBLAZER SS PARTS!
evap assembly with bracket 30.00
air ride compressor with bracket 8k miles 100.00
2 abs modules 80.00 each
07 trailblazer wiring harness 175.00
nib trailblazer trailer harness gm part # 10365399 20.00
trailblazerss power seat track & switch panel 75.00
06 ss guage cluster less than 65k cant remember exact miles 80.00
trailblazerss oil pan &pick up 175.00
tbss oil pan 125.00
G8 PARTS
pontiac g8 oil pan and pickup 180.00
g8 transmission crossmember &mount 50.00
2 rear 02 sensors 10k miles 50.00 for both
97-04 vette batwing oil pan 75.00
98-02 camaro /ta parts
abs module with master cyl. &booster 75.00
t/a passenger air bag 75.00
2000 camaro v8 cluster I think 165k 50.00
nib gm 12586482 ls1 timing chain 15.00
6.2 PARTS
nib l92 rocker stands part#12600936 15.00 4 the pair
08 6.2 intake fuel rails and injectors off a 8k mile motor no throttle body 160.00
08 6.2 escalade engine harness off 8k mile motor 175.00
NITROUS PARTS
(2) nib nitrous outlet part#00-50006 .310 fuel soleniods 80.00
nib nitrous outlet part# 00-50004 .125 nitrous soleniod 80.00
good used cond. -4 16ft. nitrous line 30.00
good used cond. -4 14ft. nitrous line 25.00
good used cond. -6 14ft. nitrous line 45.00
STEREO STUFF
db drive class d 750 watt amp used 3 months 170.00
jl audio w7 10” sub in ported box used 6 months 275.00
THANKS FOR LOOKING ANY ?S CALL OR TEXT 803 707 4780
ALL PRICES ARE OBRO!!!!!!!IF U DONT SEE IT LISTED IT DONT MEAN I DONT HAVE IT TEXT ME UR LIST I MITE HAVE WHAT U NEED!!!!!
