Carbureted LSX forum - who uses wideband o2 setup on their carb motor?
streetknight2
12-22-2011, 08:28 AM
What is the best way to do this? I'm doing a carb'd LQ4 in a fox. I would like a way to at least monitor and preferably datalog the wideband if possible. What are my options and ballpark cost?
TIA
Pop N Wood
12-22-2011, 08:57 AM
There have been several threads with people talking about their set ups.
I bought an Innovate LM2 some time ago. I don't have it hooked up full time; I just use it for tuning. The unit is a little pricey and the quite a few people have complained about it being flaky. But in the half dozen car mag comparisons I have read it is always the most accurate and fastest responding.
IMO the data logging is an absolute necessity. Kinda hard to stare at a display at WFO. If you get one that records then having RPM is another necessity. The LM2 has 3 other recording channels available. Lots of guys hook up the MAP sensor from their MSD ignition and some even go so far as to hook up a TPS to the carb. With all that info you can really dial in a carb. The unit comes with free software and SD memory card that allows you to make a run then figure out your trouble areas when you get back home.
xpndbl3
12-22-2011, 12:17 PM
I just put my tach and wideband next to each other in the car then built a bracket to attach my digital camera to the roll bar and its a poor mans datalogger ;)
3pedals
12-22-2011, 12:49 PM
I put my wide and gauge up on the dash durring tuning, it has a BRIGHT red LCD display, so it is easy to see while driving.
I run a NGK setup, it was $250 for everything. It doesn't datalog but has an output to connect to an external data logger
ZONES89RS
12-22-2011, 03:22 PM
Think I paid 180$ for my innovate wide band, it has been great, helped me dial in the carb and pick .2 more tenths in the 1/8th. It is above my tach and I just watch it when I am driving down the road in 3rd gear while WOT, even 4th if I have room.
camarof41_383
12-22-2011, 07:27 PM
I have an Innovate LM-2. It works very well, I like the data logging capability. Makes it much easier to tune and diagnose problems.
Tireburnin
12-22-2011, 11:15 PM
Another cheap alternative WB that includes data logging capability is the Zeitronix ZT-2. It's $270ish without a gauge. It logs to internal memory and can be downloaded later (a laptop isn't required to be attached for recording like some setups). It is also a hardwired setup rather than a removable/temporary setup like the LM2 etc.
vandal699
12-23-2011, 05:25 AM
I use an MTX-L on my own and customers cars. It saves so much time and guess work it becomes priceless but new they are under $200.
topbrent
12-23-2011, 06:19 AM
I like the Innovate Motorsports MTX-L.
It is a simple, self-contained unit that comes with the O2 sensor, all cables and the gauge.
- Hard to get more simple.
Inexpensive also, as you can find them online for around $180.
When tuning technology is this inexpensive, it is hard to justify the reasoning behind not using it.
http://www.innovatemotorsports.com/products/MTXL.php
http://www.innovatemotorsports.com/products/images/MTXL_All_Web.jpg
ZONES89RS
12-23-2011, 03:30 PM
Yep, that's the one I have.
67RS/SSx2
12-27-2011, 10:25 AM
How do you install these on cars with true duals? Does it matter if you are only monitoring one exhaust pipe?
streetknight2
12-27-2011, 10:31 AM
This is what I'm wondering too. I've only used one on my turbo buick before and have it in the single down pipe. I think FAST makes a stand alone that uses 2 sensors and averages, but not sure. I'm hoping someone else will chime in on this.
Tireburnin
12-27-2011, 10:47 AM
You don't 'need' two sensors, but it would be more accurate. You will be fine just picking a side and installing the sensor. The variance isn't that significant between sides.
fastass2000
12-27-2011, 09:31 PM
i use the fast wide band with the dual sensor set up it also has playback on it..wrks amaizing
Pop N Wood
12-28-2011, 07:56 AM
Do you see much difference in the readings from the left and right sides? What do you do differently if you do?
hifi875
12-28-2011, 10:27 AM
i am assuming the wideband will help you when setting the idle mixture screws? Will it also help with jet sizing? Excuse me for my ignorance!
ZONES89RS
12-28-2011, 05:49 PM
It will help you dial in any engine, efi or carb by allowing you to monitor changes in jetting/fuel from idle to WOT, tuning without one is a thing of the past, you can tune without but there is no more direct route to get a carbed motor performing as close to efi as possible than with a wide band to help you do so.
hifi875
12-28-2011, 06:00 PM
will it also cut down on the gas fume smell if you get the a/f ratio in the correct range.
Nic Morales
12-28-2011, 07:51 PM
Well daguum im gonna go get one asap. I love this topic , it has been on my mind for a while and experience is the best teacher. !
ZONES89RS
12-28-2011, 10:58 PM
You will really get to understand jet changes even more, and then there is the dine tuning.
