Sint3k
12-22-2011, 04:28 PM
Hey guys when i replaced my rotors i dont remember what kind of E Brake setup we have. Is it a Rotor of HAT assembly or do we have adjustable disc e brake ? Anyways i've warn em down or stretched the cable one and i need to tighten the cable or adjust the E brake itself
badata
12-23-2011, 05:18 PM
I'm sure we have the drum inside the hat of rotor. Just found my e brake not working either. I was able to check my cable is fine its nicely covered underneath. I thought maybe some adjusting. When I have time. Keep us updated.
badata
12-30-2011, 06:36 PM
Fixed mine today. Removed rotor and at bottom there is a adjuster wheel. Turning it you will see the pads seperate at the bottom. Just play with it untill they grab good but not draging on drum. Works like new
