5.3L to 383 CID
Old 12-22-2011, 04:54 PM
N2OBaby's Avatar
Question 5.3L to 383 CID
I have seen on the internet where 5.3L blocks can be bored to LS1 size and with 6.20 rods & 4" crank it makes for a 383.
It would be nice to have a 11-12:1 CR with RHS or TFS heads(I hear LS3 heads don't work with 3.902 size bore) for use with E-85 & a N2O cam(112-116+LSA).
Anyone doing this here?
Old 12-22-2011, 04:59 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
https://ls1tech.com/forums/search.php?searchid=16270505
There are a LOT of people doing this and posting about it often (more often 6.125" rods instead of 6.200" though). What questions do you have about it?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-23-2011, 05:44 AM
RezinTexas's Avatar
This is what I'm currently building:
2004 LM7 block
3.903" bore
6.125" Scat I-beam rods
1.110" comp height, -3cc Wiseco pistons
4" crank, brand not yet decided
block deck machined to -.010 piston deck height
Target is 11.1 SCR
Here is a good read for you:
http://www.truckinweb.com/tech/engin...ild/index.html
Old 12-23-2011, 10:12 AM
BRDMAN's Avatar
it can be bored to a 3.902 in which you can build a 382 or if your going stock stroke it will be a forged 5.7l
Old 12-23-2011, 09:28 PM
N2OBaby's Avatar
What is the effective CR limit for 91-93 Octane with aluminum heads?
Is 10.2-11.25:1 a better idea?
Old 12-24-2011, 08:18 AM
RezinTexas's Avatar
my builder recommends 11.25 max for street engines
Old 12-28-2011, 01:05 PM
N2OBaby's Avatar
Question
I was wondering if using an LS2 intake & ported LS6 intake as well as a LS6 cam on a 383(5.3L stroker) would perform well(but on a smaller budget)?
Old 12-28-2011, 01:43 PM
95ONE's Avatar
Everything you mentioned, (and more) but not the stroker crank. (wish it were in the budget)
Old 12-29-2011, 11:05 AM
It would be very difficult to draw a hard line limit for static compression on pump gas. There are way too many variables involved: weather and climate, the rest of the engine combo, vehicle specs, application, etc. Many will draw a "soft" line around 11.5:1 static, which will allow for many to run pump gas, but definitely make sure your builder has the entire combo purpose built with pump gas in mind.
__________________
Old 12-29-2011, 02:14 PM
mark21742's Avatar
I broke that line....I'm running 12.5:1 on pump gas....but my cam drops me down to 8.22:1 dcr
Old 12-29-2011, 02:46 PM
^^And that's why I said "soft" line Good air, later IVC points, good tuning, etc make that possible!
__________________
Old 12-30-2011, 01:22 PM
mark21742's Avatar
85 degrees after bottom dead center.....and still peppy
Quick Reply: 5.3L to 383 CID
