Trams am dash in Camaro.
I have a 99 camaro, I have a a 2002 trans am dash, and i have 3 wire harness, a v6 camaro, a z28 camaro and the trans am one. what should i use to make every thing work, i would like to make the steering wheel controls work(trans am wheel) but it dosnt have to.
You shouldn't have to use a different wiring harness, the dash should swap right in, you will have to move and re-wire a few things, fog lights, certain switches, etc depending on what options you got on your car.
The steering wheel controls is independent from the dash swap, if you plug everything up the way you had it before the swap, I don't see why the radio controls won't work.
