What's the trick?
What's the trick?
I have 2.5" turbo inlets and therefore bought 2.5" t-bolt clamps. For the life of me I cannot get them on no matter how loose I get them. Is there a trick or should I have gotten a half a size bigger T bolt clamps. I also tried my 3" intake pipe and coudln't get the 3" T bolt clamps on.
Any suggestions would be great. I am using them to hold on the silicone couplers for the turbo's and throttle body. I did put a very small bead around the ends of the pipe to hold the coupler. The coupler fits no problem but the T bolt doesn't.
I don't know if this is your situation, but when I was ordering 3.5" ID clamps there were two to pick from. One was for black rubber and the other was for silicone. I'll take a look and make sure what I just said is not just babble. Are your joints black rubber by any chance?
Just looked, check this link out.
http://intakehoses.com/Merchant2/mer...gory_Code=TBC5
Just measure the OD of the silicone pipe when its fitted over the hardpipe.
Then buy clamps to suit that. Dont buy too big though, try and aim towards the lower end or the middle of any sizing. And definitely not at the tight end.
