So Much Torque, It bent the Chassis...
Well no, not as dramatic as that... But i did See the LCA (Lower Control Arm) On the Passenger side of my car is bent.
Not sure what could of caused it, but this may be the reason, For the Excessive wheel hop i Would get when i would do a burn out on the street. It shook so bad or hop'd that i thought i was going to break something. Maybe this is affecting my 1/4 mile time also, who knows....
This is one more thing i Am going to have to replace, does anyone here recommend a specific type of LCA? And do they improve Lauch??
Thx everyone, Merry XMAS!!!
My wife got me a set of Spohn LCAs with Delsphere Bushings for Christmas a couple years ago. Prior to installing them, I can't say I noticed much Wheel-hop from my 99. (Not that I beat on my car all that much either.) I will say that I know I haven't had ANY Wheel-hop since putting them on the car. That being the case, I like them a lot and would recommend them to anybody who's in the market for a set.
Wheel hop can cause a lot of damage on any car. Tons of people run aftermarket LCA's on here, including myself. I have Metco's that came with the car but am planning on getting adjustable Spohn's(with Delsphere bushings) so I can fit 28" slicks. I've never had any wheel hop with the Metco's.
also with age your springs get weak.bushing get soft and can't control suspension motion as good.with your power level you would benefit from alot of suspension up grades.LCA,torque arm,springs ,and shocks.
I definitely recommend LCA's I have non adj UMI's. I also got set of relocator brackets. I'm factory ride height and they helped will wheel hop tremendously. On a car that is lowered IMO they are a must.
Would aftermarket LCA's and relocation brackets be nessecary upgrade for an H/C/I/E LS1 mainly street car with some strip time? Just curious. Would an adjustable setup be best?
get LCA's, if your car isn't lowered you probably don't need the relocation brackets. You also need an aftermarket torque arm. Subframe connectors would be good too
Here is the Thing... Im not planning on lowering my ride at all, just dont want to deal with all the extras.
So In my case will the adjustable Sphoon LCA' w/ sphere bushings be enough?
Also when it comes to shocks, Do i just get the ones the car came with, or is there a better shock out there with a good price.
Let me know the same for springs but dont think i need them...
Rod ended bushings are going to be more harsh and more noisy than rubber bushings but allow articulation (which is good for handling).
Poly bushings can ride better but are still more harsh than rubber, but they can bind causing bad handling and ride quality.
UMI makes roto-joint LCA's which are quiet, articulate and ride decent for what they are, IMO its either that or solid rubber bushings for a street car.
Definitely use the search function and read about anything before you buy, you will learn a lot.
Otherwise I would look into some SLP Bilstiens, these are far superior to the stock decarbons but cheap (cheapest good shock IMO). Better ride and handling with these.
This all depends on what you want to do with the car and what you are willing to deal with.
I personally would never waste your money on buying stock shocks, they have horrible valving to begin with(which means bad ride, handling and control) and it only gets worse with wear over time. Worn out stock shocks make decent drag shocks, so if going strait is all you care about you can stick with them.
If you don't want to lower then you don't have to replace your springs.
I can end my Thread right here... Thank you very much for all the well explain info, Deff sounds like you know your stuff.
I'll Start my research now and start buying.
Thx to all...
