Dynamometer Results & Comparisons - measuring power on dyno from low idle rpm
foler
12-25-2011, 10:58 AM
hello
Do I can damage any components on car if I measure power from idle rpm to maximum, or maybe 1000rpm-?
venom ws7
12-25-2011, 06:53 PM
You can't start from idle in 4th gear you will probably burn the clutch after a couple of runs I also dont think you can do it in 3rd gear if the car was auto.
Why do you want to measure the HP or TQ under 1500rpm??
The lowest RPM I started at is 2500rpm I was running a boltons SRT10 Viper I wanted to see the low range HP&TQ :lol:
soundengineer
12-25-2011, 07:32 PM
hello
no more damage than you would incur by doing it on the street...
if its not a loaded dyno, then it will be slightly less stress than on the street
either way... you really dont need to do a pull from that low... start around 2500/3000 ish and pull to the top.
Slowhawk
12-25-2011, 09:06 PM
You can do it if you want but I'd suggest a pull from 1000 to 4000rpm or so. Then do the 3-xx dyno pulls.
foler
12-26-2011, 02:06 AM
I want to know low end tq for comparison purposes. dyno is maha lps 3000
http://www.youtube.com/watch?v=sQKOKcdKjCw
Started a lot of pulls from 2000 rpms, but never from that low. A lot of the turbo cars I tuned would be at peak torque by 3000 rpms.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
