Carbureted LSX forum - 6.0 carb help (need cam setup)
Goat's ss
12-25-2011, 08:03 PM
I got a 92 silverado Im going to convert to carb and want a nice healthy cam for it. I plan on running stock heads and bottom end and maybe a small shot of nitrous!
Any help with info on this swap is needed. This will be started soon very soon.
c4lhozwalte
12-26-2011, 12:55 AM
what are your goals for the build?
Paul57
12-27-2011, 05:26 AM
What type of HP and ET are you looking for?? What kind of gears do you have??
A converter needs to be your first mod if you haven't done that already.
For regular street use I would keep the cam under 230 duration.
ZONES89RS
12-27-2011, 06:32 PM
Really lacking the info we need to give any advice, what engine will be used?
Goat's ss
01-16-2012, 11:31 PM
6.0 from a truck will be used cause it is what I have at the moment and I might stay fuel injected and do a turbo setup on it.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
