Quick cam spec?
Old 12-26-2011, 04:24 PM
xdanny510x's Avatar
Default Quick cam spec?
Im having a cam specd by a vendor off this board and hes asking me if i have a desired shift point or redline ...and im not sure...my car is a 99z28 th 400, 12 bolt rear with 3;73 motor is a lq9 stroker with l92/ls3 heads milled to 64cc ,- 4cc pistons..car will mainly be used for track and some street use
Old 12-26-2011, 05:26 PM
JPH
JPH's Avatar
How many cubes? How much compression? What size stall?
Old 12-26-2011, 06:03 PM
xdanny510x's Avatar
Its a 404ci ..compression is around 11:8:1 and the stall is 4400
Old 12-26-2011, 06:08 PM
JPH
JPH's Avatar
Nice. Depending on what intake you run, a cam in the 247/259 .624/.624 112 range should get you were you want to be. Your 3:73s should be swapped out with 4:10s+.
Old 12-26-2011, 07:03 PM
xdanny510x's Avatar
The ? He is askin me is where i wud want my cam to redline at or shifted at before he can spec me something out...
Old 12-26-2011, 07:19 PM
10 Second Truck Club
67SS509's Avatar
With those heads and cubes shift it around 6500 and redline about 6800
Old 12-26-2011, 08:51 PM
JPH
JPH's Avatar
My bad I read quick cam spec instead of just REALLY reading your whole paragraph. lol Sorry. The manifold will probably make it peak by 6400-6500 for sure, but should carry out 300-400rpms past that, so I would tell him 6800-6900k.
