Now that I have the 799 heads I need a list of everything needed for the head swap...
Old 12-28-2011, 10:36 PM
1sicss's Avatar
Default Now that I have the 799 heads I need a list of everything needed for the head swap...
I also have a couple of questions. Will I need to replace the gaskets on my ls6 intake or are the ones that are on it right now be ok. I know I will be replacing the lifters while I'm in there so what all do I need and if there is any links to a head swap I greatly appreciate it. Also I need one coil from an 2008 tahoe. One more thing how do you use a pushrod checker on an ls1 or any engine for that matter. I have one but have never used it.
Old 12-28-2011, 10:38 PM
1sicss's Avatar
Can you even use truck coils for a camaro or does it have to be camaro coils?
Old 12-29-2011, 12:01 AM
strokerrace's Avatar
Gaskets are reusable buy replace for insurance against leaks.
LS7 lifters, LS2 lifter trays.
Ls1howto.com look at "head swap" for step by step
Why do you want truck coils? Proven to have no gain and they are different on an 08 I believe anyway.
Insert solid lifter in tray and put head on block with pushrod checker in. Adjust to zero lash and count turns to see the right size.
Old 12-29-2011, 08:50 AM
thunderstruck507's Avatar
Required:
Head bolts
head gaskets
lifters
water pump gaskets
oil/filter
coolant
have the heads surfaced
check valve job for adequate sealing
Recommended:
intake gaskets
valve cover gaskets
valve seals
I'm sure I'm missing something...
Old 12-29-2011, 09:51 AM
1sicss's Avatar
About the coils I have a 98 ls1 with perimeter valve covers stock but I got 08 coils from a tahoe along with valve covers and brackets; or can my stock coils work on the center bolt covers with the new bracket if so ill just use my stock coils.
Old 12-29-2011, 01:48 PM
Im not really familiar with those without seeing them. Simple answer, try it and see... Bolt the coil tray to the valve cover and see if the old coils will fit. They should but im not certain. If not you can use the new coils but the connectors might be different idk.
And everything as listed above is a must for the swap plus obviously push rods once you determine the length. Also a good idea to check ptv clearance and upgrade the trunion bearings if using stock rockers.
Old 12-29-2011, 02:48 PM
1sicss's Avatar
Default Lifter trays
Are they a must, or can I use my stock lifter trays?
Old 12-29-2011, 06:10 PM
They arent a must but theyre cheap and the trays are made of plastic so with all that heat and age if one cracked the lifter could turn. The ls2 trays hold the lifter tighter as well
Old 12-30-2011, 01:02 PM
Kingc8r's Avatar
It's better to not skip out on cheap precautionary stuff than to skip it and have it fail and take out something expensive...
Old 12-30-2011, 02:20 PM
2000PewterT/A's Avatar
I completely agree, I hate when people do a full head and cam swap and then try to cheap out and reuse something cheap and then have it come back and screw them in the long run.
Old 12-30-2011, 03:16 PM
Sales1@Texas-speed's Avatar
Just give us a call, we have complete packages for that swap!
