bottle mounting question on f bod
Old 12-29-2011, 08:35 PM
GormanRacingZ28's Avatar
Default bottle mounting question on f bod
whats up guys i just recently picked up a nitrous kit to learn with ( small kit) and then will go larger but i was wondering were are you f bod guys mounting the bottle and running main pressure line i cant really find a good spot i am willing to delete rear seats but dnt know how if that is what yall are doing
and is there an existing hole i can use to run line dnt really like drilling holes into my car if youn know wat i mean plz help and thanks guys any info is appreciated
and its a 10 lb bottle
Old 12-30-2011, 09:05 AM
supersick99z's Avatar
Tunnel mount or spare tire mount
Old 12-30-2011, 10:35 AM
zooguy's Avatar
http://a5.sphotos.ak.fbcdn.net/hphot...88586317_n.jpg
here is my tranny mount from nitrous outlet
Old 12-30-2011, 11:16 AM
Doug G's Avatar
Mounting inside the passenger compartment... it is recommended to install a blowdown tube.
Old 12-30-2011, 11:21 AM
joeZ96's Avatar
I never use the T-tops, so I have a 15lb. bottle and NANO 3000 mounted sideways across the T-top holder. I used 8AN stainless braided line for the blowdown, cut a hole in the plastic, and out the bottom of the spare tire drain grommet. I tilt the bottle slightly so the pickup is in the back and I've never had any problems. Easy access and works great. I ran the mainline, as most guys do, inside the car along the passenger sill and into the engine compartment through the PCM grommet behind the glovebox.
Old 12-30-2011, 04:41 PM
zracer323's Avatar
I have mine mounted on the tranny tunnel. Rear seats can still go in and all the lines are hidden. It's nice to be able to reach the bottle from the drivers seat and see the pressure gauge.
Old 12-30-2011, 05:07 PM
@ z racer were can i get the bottle brackets for tunnel mounting and how did you hide the line also any pics you can post and thanks everyone
Old 12-30-2011, 07:51 PM
ryant13's Avatar
Behind passenger seat mounted to plywood. Line ran through opening behind glove box or small hole in floorboard.
Old 12-30-2011, 11:07 PM
35thsscamaro02's Avatar
Now you see it
Now you don't
Old 01-01-2012, 10:35 AM
@ 35th ss that is ******* sick man but i think i am going to go tunnel mounted so i can monitor pressure and dnt have to stop and get out to turn bottle on
Old 01-01-2012, 11:22 AM
soundengineer's Avatar
Old 01-01-2012, 03:42 PM
zracer323's Avatar
I have a tunnel mount bracket from HSW. I think some of the other vendors have them as well. The feed line routes under the seat bucket and through a grommet under the car.
Old 01-01-2012, 08:11 PM
I think having on tunnel looks sick just wasn't for me. I have remote bottle opener and n20 pressure gauge on pillar. Well I should say I did have it there. There's a boost gauge in it's location now. But I won't be out of the n20 game for long hopefully.
Quick Reply: bottle mounting question on f bod
