Corvette Performance - Do I have to pull the trans and torque tube to replace the diff?
87silverbullet
12-30-2011, 01:34 PM
I am helping a buddy of mine replace the diff from a 2.73 to a 3.42 and I am trying to see if I could gain enough clearance to just drop the trans a little and pull the rear off and put the new one in?
I really don't want to have to pull the whole thing out if I don't have to.
feeder82
12-30-2011, 01:54 PM
Yes no problem just watch the clearance between the back of the intake and the cowl when you lower the TT
87silverbullet
12-30-2011, 04:34 PM
Cool, thats what I needed to know. I pulled a few before when I worked at the dealer but that was over 12 years ago.
BMR Sales2
12-30-2011, 04:44 PM
Like Feeler82 said you can lower diff/trans torque tube assembly enough to get the differential of the transmission and still have enough clearance between the engine and the firewall. I have done it this way quite a few times.
Larry
12-30-2011, 05:28 PM
Are you installing a Z06 differential? I've been looking over six months for one and can't find. The C6 3.42 won't fit. The Z06 requires minimal modification.
LS1LT1
12-30-2011, 06:33 PM
Are you installing a Z06 differential? I've been looking over six months for one and can't find. The C6 3.42 won't fit. The Z06 requires minimal modification.I was thinking that it was actually a C5 automatic that they were working on (though I might be wrong in assuming that), upgrading the base C5 automatic's 2.73s to a manual's 3.42 which can be done much easier in C5s then it can in our automatic C6s. :)
Larry
12-30-2011, 07:40 PM
I was thinking that it was actually a C5 automatic that they were working on (though I might be wrong in assuming that), upgrading the base C5 automatic's 2.73s to a manual's 3.42 which can be done much easier in C5s then it can in our automatic C6s. :)You may be right. I guess we were both assuming!
87silverbullet
12-31-2011, 08:46 AM
Yeah its a z06 diff from a c5. We found it on a google search in a corvette only junkyard in Picayune, MS. If you call them make sure they don't try to rip you off. They have $650 on their site and when we called they told us $1350, we told them F U and then they came down when we told them they had $650 on their site.
Yeah we are upgrading a c5 automatic from the 2.73 to 3.42.
Didn't the c6 auto's come with 2.56? I'm not really a vette guy so I don't know.
87silverbullet
12-31-2011, 11:04 AM
How long did it take you to the point of getting access to unbolt it?
When I took out the torque tube and all it took me a little over 2 hours on a lift at the dealer years ago.
Hopefully its like riding a bike, you never forget.
LS1LT1
12-31-2011, 11:33 AM
Didn't the c6 auto's come with 2.56? I'm not really a vette guy so I don't know.Yes, the only ratio available in 2006/2007 was the 2.56s. In 2008/2009 a 2.73 rear became optional on base automatics and standard/part of the package on Z51 optioned automatics.
In 2010 all base automatics again came with 2.56s with the only way to get 2.73s being to order a Grand Sport automatic which came standard with the 2.73s, which is how it still is to this day. :nod:
paint it black vette
01-05-2012, 06:46 PM
step it up put a set of 3.73 and a 3600 stall before you install and snap some necks :D
87silverbullet
01-06-2012, 07:09 AM
If thats the case we wouldn't be putting in a whole diff. It's just easier for us to swap it.
The converter will be later down the road and a cam will go in also. :nod:
BigMilan312
01-18-2012, 03:26 AM
You don't have to remove everything, just lower it enough to get the old diff off and new one on
BMR Sales2
01-18-2012, 08:41 AM
It took me roughly an hour or so. Once you get back in there it will come to you. It is not bad at all but I have done a ton of trans/diffs/clutches in vettes so it is kind of like second nature.
Larry
01-18-2012, 09:15 AM
It took me roughly an hour or so. Once you get back in there it will come to you. It is not bad at all but I have done a ton of trans/diffs/clutches in vettes so it is kind of like second nature.An hour to take it out and maybe an hour and a half to reinstalled. And a dealer here in Houston quoted me $700 to change out a differential in my 08.
Imstock2
01-29-2012, 11:24 AM
Yea 700$ for removal/install on a diff is about average... that's the corvette tax...
Red99TA
01-29-2012, 03:05 PM
$650...that seems steep. I bought a used C5Z diff last year for $400 that's just sitting in my garage as a spare.
87silverbullet
01-29-2012, 04:46 PM
Yeah. I looked on ebay and the classifieds on here and couldn't find anything . Ebay had them for 600 but the shipping would of put it over 700. I found that junk yard which was a 20 minute drive away. Plus that diff had low miles. The ebay ones had like 90k+ miles.
Update: The diff is in and the LT's are on. He has the XS Power 3 inch mufflers on. He was supposed to go to the dyno yesterday but couldn't make it. i think he is going to go next week.
