bigest streetable cam
Old 12-30-2011, 06:17 PM
badseed1's Avatar
Default bigest streetable cam
Hey i was wondering what the biggest streetable cam i can buy for my car. I have a 2000 Trans Am WS6 4l60e
Old 12-30-2011, 08:02 PM
xdanny510x's Avatar
Ms4 , t rex
Old 12-30-2011, 08:09 PM
MikeWS6's Avatar
ms3 is kinda streetable... i guess
Old 12-30-2011, 08:21 PM
wildcamaro's Avatar
If you dont want surge from cam when u go to brake get somethin 224/230 or less, just my experience bc if u get a ms4 or 3 u aint gonna have no torque under 4 grand (compared to stock)
Old 12-30-2011, 08:24 PM
Kingc8r's Avatar
I agree My buddies MS4/4L60 car wasn't impressive. But it is now that he changed things up. I like 228 or 230-236s in street cars.
If you're going to run a big cam make sure you have a good tune, the right gears and supporting mods
Old 12-30-2011, 08:27 PM
garygnu's Avatar
big cam = slow street car.you will need a great tuner ,gears,big stall,built trans,etc.whats your budget and goals ?you don't need a big cam to go quick with a ls motor.243 heads and a EPS cam will get you low 11s with all the right bolt on.read and learn alot more before you buy anything.
Old 12-30-2011, 08:40 PM
roninsonic's Avatar
I'm streeting an MS3 with a Yank 4000 and 4.10's.
Old 12-31-2011, 05:39 AM
Blk98Vert's Avatar
Something in the 24x/24x on a 114 or so. But as said dont go for the biggest that will fit
Old 12-31-2011, 06:41 AM
wildcamaro's Avatar
Those big cams need a big stall in an auto....my 224/230 cam doesnt quite match up perfect with my stock converter which is a little tight but any bigger and id say a converter is requried..
afastm6's Avatar
Bigger isnt always better its all in your combo not just cam shaft
Old 12-31-2011, 06:57 AM
Captain Double Post
BOBS99SS's Avatar
ms4 and other big cams has everything to do with other mods, a big cam on stock gears is going to be such a dog, op big cams are not a budget way of going fast, it takes max effort parts to get them going, ask me how i know lol, the ms4 is a badass cam and can make a wicked car in the right hands, im talking 4.30,4.56 gears,fast intake,injectors,1 7/8th headers,a good dual exhaust ,etc those are parts to start with, op i hope you know you can get a big cam sound out of a much smaller profile, but the big cams are only as good as the parts around it
Old 12-31-2011, 07:04 AM
Captain Double Post
BOBS99SS's Avatar
im a big cam fan, but 75 percent of guys that go with a huge cam leave so much on the table, and dont make the mistake so many do after watching some idle clips on youtube and get a cam just because it sounds cool, that is such the wrong thing to do, and asking others what they think is streetable is not a good idea, some are hardcore and can deal with surging,shaking,loud, etc others cant, what you should do is go into detail about what you use the car for and future mods that you plan, have you done bolt ons yet? if not start there
Old 12-31-2011, 07:15 AM
CBAR02SLP's Avatar
Default Biggest street cam?
Best post yet on the question!
Old 12-31-2011, 08:21 AM
ls1 down under's Avatar
Just to throw in here, why not if auto opt for something like a 220/224, 112 lobe with .575/.575 lift ? I have this cam and is the smallest size i have put in an ls1 yet and it surprised me and i have stock stall converter in it too . it sounds tough as nails thru a twin 3 inch system. and it has a great lumpy lope sound at the lights but not over the top with fantastic street manners.
But in saying that it comes down to tune also, i first had it tuned by a cheaper place and holy ****, it was nothing compared to going to a place that is very reputable by many people and getting a decent tune. also, what and where do you want the power ? low to mid , mid to high etc Makes a difference imo.
Old 12-31-2011, 09:11 AM
Steve Gunn's Avatar
You'll get many different opinions. Here's mine. I wouldn't go bigger than a low 230's cam. My Torquer 2 on a 112 is the biggest I would go on a driver. With a really good tune, it's livable in all street situations. Any more overlap and you'll compromise drivability and tuneability for a couple more high rpm horsepower.
Old 12-31-2011, 10:09 AM
KC Henry's Avatar
Depends on what you mean by "Streetable"
Coming from someone with an EPS 234/246 cam in a stock LQ9 6.0L
Streetable daily driver = high 21X to low 22X
Streetable weekend toy = high 22X to low 23X
Old 12-31-2011, 10:28 AM
Transam1's Avatar
i have the Raptr cam 236/242 on a 111 LSa with a 5000converter and 3.42's not the best on the street....kind of annoying unless im just out to play around. so i would say if you are driving the car a lot, then listen to the people talking about the smaller cams...can still make them sound choppy! i might drive mine once a week so i can deal with it.
Old 12-31-2011, 10:42 AM
studderin's Avatar
Bigger as in big power?
https://ls1tech.com/forums/dynamomet...o-numbers.html
I have this custom cam I had done, Makes 440+ on stock heads. Drives just as good as the streetsweeper I had before, the never surges or bucks. Makes more power then trex, that made the most power. And drove bad, surges and bucks and low rpms.
Old 12-31-2011, 12:12 PM
JPH
JPH's Avatar
276/284 on a 108 is the BIGGEST I would run. No I am just joking. I would stay less then 239* @.050 on both intake and exhaust sides and use a LSA in the 113-115* range.
Old 12-31-2011, 01:06 PM
badseed1's Avatar
I know im going to need a stall and gears and i have another car to drive because i live in new england so the weather always sucks i just want something that sounds very mean and performs just as good i dont care about bottom end power that much i just want my trap speeds to be up there my cars is completely stock and its doing 108 at the end of the track i wanna do at least 114-116 is that possible with cam stall long tubes and full exhaust? ive been in a a lot off fast cars and i like it when they pull on the top end.
Quick Reply: bigest streetable cam
