Bucking and surging?
Old 12-30-2011, 07:44 PM
STAR's Avatar
Default Bucking and surging?
Big cams cause this and there's only so much one can tune out, but what are your findings? I'm asking about overlap? Is say 15* of overlap too much to completely tune out?
Old 01-01-2012, 04:47 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
depends on the size of the motor... but for example 346 with a cam with 15 degrees of overlap will likely always buck to a degree at and under 1500 rpm... you can generally clean it up with timing adjustments to a degree, but thats about it (assuming maf/ve is dialed in)
Old 01-01-2012, 11:03 PM
STAR's Avatar
So would 15* in a 402 behave the same or better?
Quick Reply: Bucking and surging?
