oil feed and drain
oil feed and drain
where are you guys tapping the oil pan for feed and return for a turbo setup? pics would be great.
i found this for feed, what do you guys think?
http://vtsql.gkvbf.servertrust.com/L...ck-p/cbr02.htm
That is the feed I am using. So no picture required. I tapped mine with -10 fittings right in front of the oil pan by the balancer. Most thought the balancer would get in the way but it doesn't. I used a 90 on there and it slopes oh so slightly but will drain with no issues.
Here are some pics.
Here are some pics.
The CBR oil block sold through Modular Turbo is a nice piece.
https://ls1tech.com/forums/attachmen...t-100_1297.jpg
https://ls1tech.com/forums/attachmen...t-100_1298.jpg
https://ls1tech.com/forums/attachmen...t-100_1296.jpg
The feed I used that port right above the oil filter that most use. Just drill it out and tap it out. return I had a guy that can weld on the bung
Is that CBR just for a feed or is it a return as well? That thing is pretty nifty.
