Went from m6 to a4
Old 12-31-2011, 02:29 PM
flewbyyou04r1's Avatar
Default Went from m6 to a4
i have a 2001 ws6 and i am doing a trans swap, got everything but the computer.. now im wondering will my m6 computer work? i was told that all the tuner has to do is swap to auto in the tuning? is this true? also if i get a different computer where can i find one and is there a way to have my vin flashed into the computer just in case i bring the car to a state that requires emissions? i know that a 98 computer is different than a 2001 is a 99 the same as mine? any help would greatly be appreciated!
Old 12-31-2011, 03:28 PM
INIT2WIN's Avatar
You will have to get an auto computer or have your computer flashed with an autos car calubration. As far as i know HP Tuners cant do it, or at least it couldnt when i did my swap. I had to swap the computers out of the donor car to get the auto to shift. I believe the all the computers are able to operate both the auto or M6 versions of our cars they just have to be flashed to unlock the parameters.
Old 12-31-2011, 03:45 PM
Should my tuner have the perameters? The car is gonna have to get tuned regardless...
Old 12-31-2011, 05:38 PM
INIT2WIN's Avatar
If your tuner has the abillity to unlock the A4 parameters in the computer you'll be fine. We tried to put an A4 tune in a M6 computer with HP Tuners and it did not work. U have to get the computer re-flashed with an auto shift program not just the auto tune form HP tuners.
Old 12-31-2011, 10:13 PM
roughneck427's Avatar
You can just do a trans segment swap inthe tune or flash an auto file in. I use efi live and tunercats and never had any problems.
Old 12-31-2011, 10:35 PM
I think my tuner uses hp tuners is there any way of doing it on there?
Old 01-01-2012, 07:26 AM
MUSTANGBRKR02's Avatar
Your tuner will know what to do. You have to either flash it with a A4 tune or get a A4 PCM.
Call your tuner and ask him what he needs to do it or how he will do it.
Old 01-01-2012, 09:32 AM
wait4me's Avatar
The a4 and m6 computers are identical, with Identical part numbers. It is just the Flash on the inside of the computer that is different. A tuner can change it. In efilive you would just do a full flash with the m6 file and you are ready for tweaking.
Old 01-01-2012, 10:02 AM
Blu99T/A's Avatar
I had no problems tuning my car with HPTuners when I did the A4-M6 swap. I did it and it was my first time using HPTuners period.
Old 01-01-2012, 10:18 AM
A4 to m6 u don't even have to touch anything since the trans is not computer controlled.. Ps I love your car!
Old 01-01-2012, 10:33 AM
Blu99T/A's Avatar
Not to actually drive the car, but to correct the speedo, reverse lockout, skip-shift, etc. Yes, it can be driven normally, but there are still PCM issues with the swap. It threw tons of codes too with the A4 removed.
Old 01-02-2012, 09:14 PM
blue ta when ur ready to sell that car let me know!
Old 01-04-2012, 05:04 PM
Blu99T/A's Avatar
Thank you, it has been considered a few times.
Quick Reply: Went from m6 to a4
