solidsnakecsm101
01-01-2012, 07:32 PM
I found my brothers dyno sheet while doing some cleaning today. He said i could post it.
Car specs bellow
2000 Camaro SS
6 Speed
Stock LS1 Block (with about 70K miles at the time)
Fidanza Al flywheel
Spec stage 3+ cluth
LS6 Intake
85mm TB
42lb Cobra "Blue" injectors
Tick Master
CNC LS6 Heads by Superior Automotive (they have a flow bench and flow 306/227 cfm @ .550 and 312/229 cfm @ .600)
Comp XER 224/230 .588/.592 114LSA
Scorpion New Style 1.7 roller rockers
Comp Pushrods
Comp Lifters 850-16
Melling High Volume oil pump
1 3/4 FLP Long Tubes High flow cats and Y pipe
Magnaflow Catback
Stock 10 Bolt with 3:73 gears
Here is the link to the dyno vid
http://youtu.be/Clm92HJNrMo
Car specs bellow
2000 Camaro SS
6 Speed
Fidanza Al flywheel
Spec stage 3+ cluth
LS6 Intake
85mm TB
Tick Master
Comp Pushrods
Comp Lifters 850-16
Magnaflow Catback
