your 2 cents please
your 2 cents please
I am retro fitting a 2005 LS2 into a 71 K5 Blazer, it is DBW and I have an issue, the engine will crank and run you can blip the throttle about three times and then the throttle goes dead. My source was kind enough to let me hang out at his shop and try swapping out the throttle petal, the tach module, the PCM and the throttle actuator itself all to no avail. I have two 4G grounds on the block to the frame and triple checked the grounds for the harness. This setup is for a manual trans so I believe that there has been some wires deleted. I believe that the harness came off of a 2004 because the oil sender was slightly different.
Has anybody had or heard of this. I am pulling my hair out.
Thank you in advance.
I spent 5 hours reading here looking for FAQ's and issues and did not find anything related so if it is here already and I missed it my apologies.
the engine came out of a 05 2500 HD LQ4 the harness is out of an 04, 2500 HD the guy that hooked me up has a fleet of gen III powered old Chevy muscle cars and trucks.
I have a manual trans, the harness is bare bones converted, I did not get a check engine light, EGR, VATS and all other non Vital systems are gone.
I am a noob to this site so some of the abbreviations are not familiar to me, I figured some of them out.
OK, good start, we've got something to work with. It's an LQ with a 3 bolt TB, not an LS2 with 4 bolt, correct?
Whay TB do you have?
Is the ecu a 463?
What TAC is it, plastic with metal ends?
What pedal are you using? APPS part number will help.
Where did you get the TAC to pedal harness?
Is the ecu a 463?
LS1Tech Sponsor
Second every question Gary just asked as this will help us determine what you problem is.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
Chuck, what ECM were you using in your conversion?
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Not sure, I'll have to take a look at it next time I go out to the garage. I got it with a harness from chevythuder, and it ran both my Lq9 and LS1.
This is what the guy who set it up said about the changing the comp from dbw to dbc - What I found was a table that is marked "installed options matrix vs platform type". Under platform "7" for the type of engine, the column for ETC was set as "1" instead of "0".
I don't know what it means but it works.
LS1Tech Sponsor
I would have thought you would just put a new OS in the PCM. Let me know what pcm when you have a chance if you dont mind. Thanks.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
the TAC has the metal base plate, the pedal has a number in the plastic pet 6f50, the jumper harness between the two came from a salvage yard along with the rest of the harness and engine.
I think I remember something about throttle calibration. In a stock situation when a part of the throttle system(pedal, TAC of throttle body) there is a procedure for calibrating. I'm not sure if the HP Tuners can do it or not.
Ok, I'm guessing you meant 12569162 for HDW number which is a 463 serv no. That should work on an 03-05 truck with DBW. That ecu does need a TAC and it sounds like you've got the correct metal base one.
I'm not sure on the pedal without the complete part number. You might want to check out Rockauto to see if you have the correct pedal.
If I had to guess, I would think it's the TAC to pedal harness. That's generally part of the body harness and it's pretty rare to get one out intact. You might confirm with a wiring diagram or just buy a standalone TAC/Pedal harness. I think psi has those.
I did get the jumper from the pedal to the tac, the guy that hooked me up used to own a few junk yards. I have ran continuity on the pins.
The guy that built the harness is going to make a house call, a very rare event my buddy tells me.
LS1Tech Sponsor
Dirt,
Is there a truck tune in the PCM? Can you post a picture of the pedal?
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
