Clean the pistons?
Old 01-02-2012, 08:49 PM
RealLiveMD's Avatar
Default Clean the pistons?
Doing a head swap. I noticed everyone shines the pistons. Why take the time? Am I missing something? Just want to get er done.
Old 01-03-2012, 04:17 AM
vettenuts's Avatar
Carbon can cause detonation.
If measuring PTV, carbon can give false values.
Old 01-03-2012, 05:46 AM
Captain Double Post
BOBS99SS's Avatar
^this x 2,
Old 01-03-2012, 07:09 AM
Steve Gunn's Avatar
Scotchbrite pad and carb cleaner. Cover your fenders.
Old 01-03-2012, 11:28 AM
getusumws6's Avatar
Agree with above. Cleaning the pistons is good towards measuring PTV and or flycutting, which most people do when they take the heads off to replace them.
Old 01-03-2012, 10:22 PM
RealLiveMD's Avatar
I'm just changing the lifters. I took the heads off to track down a valve train problem. Now that I have my heads and springs repaired I just want to get them back on. Im catching hell trying to clean the block. The blue scotch Brits pad leaves blue felt in all the ports. I can't find a roloc anywhere. Also I have a dremel and tried the little felt pads bit they keep burning off. There has to be an easier way.
Old 01-04-2012, 04:16 AM
vettenuts's Avatar
Try a local paint store. I found non-metallic scotchbrite pads there that worked well and they were available in different roughness.
