tach signal?
tach signal?
Lq4 transplant with truck ignition, still injected and using coil packs. Wanting to add Autometer tach....where is a good source for feed? This is all new (black magic!) to me
It is the #10 white wire in the red harness. And for some reason I had to set my tach to 6cyl mode for it work properly. Doesn't make any sense but maybe auto meter labeled the tach wrong during assembly. Also you do have to boost the wire with a 12v key hot source and run a 1K resistor between the two wires. It will work flawless. Good luck
