New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!
Old 01-03-2012, 03:15 PM
SPRAYED 01's Avatar
Default New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!
Got the new comp 8079mm on the dyno at speed inc. At about 17psi using a 50/50 mix of 93 and 110 is made 777whp and 787ftlbs. This is on a 9.5 370ci with ported 241s and a 232/236 cam.
Running through a locked 4l65e and a moser 9inch with 325 gear.
I'll post the graphs tonight.
I'm very happy with the results, car picked up 100whp going from the tc78 347 to this turbo and engine.
Thanks comp, speed inc and finish line transmission.
Old 01-03-2012, 04:16 PM
Restricted User
98Z28CobraKiller's Avatar
Very Nice!
You had an issue with the first Comp turbo, right? If that was you, what ended up being the problem?
Old 01-03-2012, 05:05 PM
SPRAYED 01's Avatar
Yes I had a back pressure issue with the first 80/79mm. It was 4:1. Comp stood behind their product and sent me a revised one. They said all they did was change the design of the comp wheel. Either way world of differance. I didn't measure back pressure this time but a 10lbs spring did 9psi so its probably not that bad. I was loosing about 4psi through my crappy ebay intercooler. I think that would bring me in the low 800whp range.
Old 01-03-2012, 06:56 PM
Restricted User
Good to know that all those years of recreational drugs haven't claimed all my brain cells.
Old 01-03-2012, 10:03 PM
compgto's Avatar
Nice! I have the T6 80/84 Comp Turbo, trying to dial it in now. Good to know they straightened it out for you. How does it spool compared to the TC78?
Old 01-03-2012, 10:05 PM
NBM-LS1's Avatar
Awesome dude!
Old 01-03-2012, 10:34 PM
SPRAYED 01's Avatar
Spool is the same, ridiculously fast.
Old 01-04-2012, 04:34 AM
skinnies's Avatar
What did it make unlocked?
Old 01-04-2012, 04:39 AM
Captain_Stabbin's Avatar
damn good numbers
Old 01-04-2012, 07:00 AM
SPRAYED 01's Avatar
Did not run it unlocked
Old 01-04-2012, 08:29 AM
SPRAYED 01's Avatar
http://s124.photobucket.com/albums/p...103_142325.mp4
Sorry for the shitty video, I did it on my phone. But this was the 777whp run.
Old 01-04-2012, 12:28 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
That's awesome Alex, let me know if you hit GLD in the spring.
Old 01-04-2012, 01:23 PM
SPRAYED 01's Avatar
I can't really go there due to no cage, I go to byron now. Hoping 2012 will finally bring me a 9 second run. I have full suspension and qa1s launching off a t brake this time and 100whp more then my 10.4 run.
Old 01-04-2012, 01:25 PM
venom ws7's Avatar
Very sick Congrats man.
Old 01-04-2012, 06:29 PM
narx66gmc's Avatar
Wow! Great setup and the video is good.
Old 01-04-2012, 08:58 PM
bad6as's Avatar
So was the old turbo t4 and is the new one t4?
My 87mm turbing 1.25 ar t4 bw was at 1.4 bp at 13 psi boost. I ran the same times on 15psi as I did 25psi.
I also have a ebay air/air what size is yours?
Old 01-04-2012, 09:39 PM
SPRAYED 01's Avatar
Yes its a t4. I'm not sure what bp is on this turbo. Il do some testing in the spring. I'm sure its less than my 348 tc78 at 16psi. Not sure the dimensions of the intercooler, its 4inch thick, about 14 inches tall and from fog light to fog light long
Old 01-05-2012, 08:19 AM
SPRAYED 01's Avatar
bad6as, what exhaust were you running when you were doing the bp pressure testing? Also what size engine? Im running a 1.32 ar with a 3.5 dp and an open cutout.
Old 01-06-2012, 12:55 PM
SPRAYED 01's Avatar
Here are the dyno graphs, i have 3 settings, a 9lb, 13lb and 17lb.
Attached Thumbnails New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!-dyno1.jpg   New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!-dyno2.jpg   New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!-dyno3.jpg
Old 01-06-2012, 01:26 PM
HydroStream6's Avatar
Nice numbers, glad you got it figured out!
I wonder why the HP peaks so low though? I have a very similar setup, 370, LS6 cam, stock 317 heads, and my PT7875 peaks at 6100 rpm.
Quick Reply: New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!
