Dynamometer Results & Comparisons - LS2 GTO w/ Advanced Induction 226/234 Cam Kit – Pics & Vid
quik95lt1
01-04-2012, 01:02 PM
I'd like to share some results of a recent cam install I did on my daily driver LS2 GTO, I installed an Advanced Induciton cam kit w/ a 226/234 .600/.600 112LSA cam in the car recently and had some great results.
The car is a LS2 06 M6 GTO Red on Red with the big ole boat anchor 18" wheels on it heres a pic of the car.....
http://i919.photobucket.com/albums/ad38/quik95lt1/061.jpg
The car previously made 373rwhp and 367rwtq with only 1 3/4" Stainless Works headers, gutted cats, a Bassani cat back exhaust, and a K&N Cold Air intake. I also tuned the car with EFI live. With the later addition of one of the older first FAST 90mm intakes and the stock throttle body the car ran 13.0 @ 110mph with a garbage 2.1 60' on stock Bridgestone tires.......
After having such great luck with Advanced Induction on my LT1 Camaro (see sig) we decided to pop one of their smaller street oriented cams into my daily driven GTO to see what it would do. The install was a piece of cake; Phil at AI supplied the correct PSI Valve Springs, Shims, and Pushrods to make the install a breeze. Two friends, 8 Hours, a 6 pack and pizza later the car was running :chug:
I tuned the car in Speed Density mode with EFI live (MAF is still inline on the car however, just unplugged), car idles awesome at 850-900rpm and sounds great also with an aggressive sounding idle. You can cruise down the street at 1200rpm in 6th gear with no bucking or surging at all and the car will also just put along in traffic idling in 1st gear ......torque is excellent in the 2-3krpm range feels much stronger than stock and the cam really woke the car up above 4500rpm in the HP department....... a second gear roll on from 35mph equals tire smoke without a burnout first.
Here’s a video just putting around the neighborhood.....
http://www.youtube.com/watch?v=zriZYkZyN64&feature=plcp&context=C3cdb10fUDOEgsToPDskKpL4gBt9moou1zBU2_R8i7
So now for the good part...........dyno day.......
After messing with some fueling i wound up at a very conservative 22* of timing and 12.7AFR to make the most HP and TQ made 422rwhp at around 6200rpm and 397rwtq at about 4800rpm great power for a street oriented cam with great driving characteristics. All pulls were made at 185* coolant temp with a 85* IAT temp.
Here is some video of the dyno pulls:
http://www.youtube.com/watch?v=6QOKGLYkNA0&list=UU11WqJz3gA4KgQWBLLosb0A&index=2&feature=plcp
http://www.youtube.com/watch?v=AQ1VrvfBwls&list=UU11WqJz3gA4KgQWBLLosb0A&index=1&feature=plcp
Here are the dyno graphs from the pulls:
As you can see below the area under the curve on the graph is awesome :D Overall the car picked up nearly 50rwhp and 30rwft/lbs tq peak.......the most impressive part to me is the broad torque curve making over 350rwtq by 3200rpm and over 400rwhp from 5300rpm to almost 7000rpm....one of the most important things i know from being involved in drag racing for quite a while now is builds that focus on area under the curve in the usable rpm range are the builds that are fast....not necessarily the ones that make the most "peak" power....so seeing this kind of power curve has me excited :D...this means with the T56's shift extension the car will never fall below 400rwhp while rowing through the gears which is nice......the flatness of the torque curve from 3500 all the way out to nearly 6500 is also great to help get this 4000lb tank moving! :D
http://www.advancedinduction.com/Dyno/MV_LS2GTO_Ai226HRKit.jpg
All in all I’m pleased with the power it makes, and the way it drives, and most importantly the way the car actually pulls on the street I’m a stern believer in racing cars not dynos :D Thanks again to Phil at AI for producing another great product for me and soon as the weather comes back around and my local NH track opens up I hope to see some 115+mph traps with this 4000lb boat :D
Patrick G
01-04-2012, 01:15 PM
Great writeup and strong results. Gotta love the numbers the AI combos are putting out. :)
stumprrp
01-05-2012, 09:30 AM
This makes me mad that your car with nothing but a cam made almost the same power as my stroker on the same dyno lol, DAMN YOU V.
I bet you didnt make 400 RWTQ at 3000 RPM though =D
quik95lt1
01-05-2012, 01:27 PM
haha lets do the heads on that thing and you'll make way more lol........nah i only made 345ish at 3k lol
stumprrp
01-05-2012, 01:34 PM
haha yeah we will see... great power though
MikeG
01-05-2012, 02:26 PM
Nice results. Now let them do the heads!
Rise of the Phoenix
01-05-2012, 03:39 PM
Off topic, but who grinds AI cams?
mac62989
01-05-2012, 04:48 PM
Great results OP! Gotta love AI's work. Get those heads ported for some insane power.
From Phil at AI, "We regularly deal with 10-12 cam grinders and often a few other obscure sources. In the end, the grinder doesnt really matter, it is the lobe characteristics that matter."
Slowhawk
01-06-2012, 08:19 AM
If you get bored with it shoot me a call. I've got a great Cam for that motor that when tuned right drives very well and makes sick power. Just did one in a A4 05 GTO. Cam only with headers made 430hp/400tq through an unlocked 3600 stalled tranny. Easy 450/460rwhp through a M6 car on my dyno (480-490 hp on Dez's)
quik95lt1
01-06-2012, 09:46 AM
Goal of this cam is a mild lobe design that will be durable with mild valvesprings for 40k+ miles and make decent power while still retaining great maners.......obveously more could have been achieved with more agressive lobes and valvetrain components but that wasn't the scope of this project.........490wrhp cam only LS2 on any dyno are big numbers....do you have these numbers cause id love to see them? also do you have a dyno graph of that cam you are speaking about? I'd like to see the hp/tq curve.....peak numbers sound good and sell but arent always the fastest as you know :D
quik95lt1
01-06-2012, 09:53 AM
as far as i know they are using comp right now.....
stumprrp
01-06-2012, 10:32 AM
Cmon now, we all know mid range torque means nothing Mike!
Slowhawk
01-06-2012, 10:35 AM
It's all midrange.Peak at 6200-6300rpm. But I know you wouldn't do it..LOL
490rwhp is a loose dynojet like Dez's. Mine are a bit lower.
quik95lt1
01-06-2012, 10:37 AM
if you have a graph id love to see it........also i have a hard time seeing a 30rwhp difference from dez's DJ to yours with a stick car.....ive seen consistant cars that have dynod on yours as well as dez's and there is around a 5rwhp difference auto's are a different story espically with large stalls......id be happy to take my GTO up to your place and do a test to see.....
Slowhawk
01-06-2012, 05:25 PM
At Dez's the dyno was very incosistant between hot/cold days. Expecially when it was under 45 degree's out. Remember I worked there for many years. But the dyno is just a tool.
Can't remember the last time I even posted a graph on here..LOL
BIGDRAGON
01-07-2012, 03:39 PM
Phil @ AI suggested that same cam for my car with the 226 port job on my 243 heads. My goal is 450 HP to the wheels.
a-low
01-08-2012, 08:42 PM
Wow! How well will that cam workout on a 3800 stall full bolt on ls1?
quik95lt1
01-09-2012, 07:29 AM
that would be easily attainable......id expect to see 460-470 if i ported mine......
and to show what i mean by drivability and a mild lobe cam i took this video the other night driving home........keep in mind its about 25* also......1100rpm up hills and cruising no problem no buck no hesitation all day long.....car drives like stock.....it truly is a mild cam designed to last a long time and drive everyday regardless of the weather.....car was tuned by me in Speed Density in Closed Loop with EFI Live.....
http://www.youtube.com/watch?v=A39Fhj6-NOE
Advanced Induction
01-11-2012, 06:05 PM
Indeed. There are dozens of cam grinders out there, and a great many have a handful of lobes I think are an ideal compromise between their relative aggressiveness and the time area they provide. Sometimes they can provide a cam, other times I mix and match lobes between vendors, and other times I alter an existing design to taste & come up with something new.
Mac is referring to our cam page, which roughly outlines my POV: http://www.advancedinduction.com/LSX/AiLSxBilletCams.php
I can only surmise that the marketing theory that one is born every minute works for you. How about a real cam comparison - eliminating the multitude of variables that an actual vehicle adds to the equation. I am happy to overlay actual data from whatever lobes you think are appropriate with Mike's current grind should you care to be measured up. :D
Ahh, another characteristic of the predatory vendor - I believe we're establishing a trend. "I own the brand of dyno that is known to put out the most consistent results... but mine just happens to be "tight" and other shop's DJ's are "loose.""
:lol:
Almost 14,000 posts, no data to support your assertion, and desperate attempts to catch the coattails flying past you like we're enjoying here? Perhaps they're born more frequently than on the minute. :D
Guys like you are what prompted that cam page I linked above. I thought the flow # games were bad, but little did I know that selling a camshaft these days has become more an exercise in theater than quantitative analysis. :lol:
Most any cam in that size range is going to make mid 4XX's with the 226cc head on a stock short block. The difference is going to be in RPM headroom, component longevity, etc. :)
quik01ss
01-11-2012, 06:25 PM
:owned: :shiner:
WayFast84
01-12-2012, 05:55 AM
I have the same camshaft coming in from them only with the 226 heads to match. I'm happy with how you said the car drives and everything you said, I can't wait for this set up.
Ju1ce
01-12-2012, 09:18 AM
I raced a cammed CTS-V that you built and tuned, it made 410whp at your dyno and I walked him good with my GTO that made 360whp at East Side in Walingford... Just sayin. I have a video if anyone cares.
Without getting into this whole thing about cams and lobes... why would someone scream "SICK POWER!" and then 2 posts later declare that the dyno is just a tool?
quik95lt1
01-12-2012, 09:26 AM
but that cant be THE PEAK POWER NUMBER ON THE DYNO SAYS SO!!!!! :lol:
lol :twak:
heres a video of the car from 0-120....regardless of what it rolled im pleased with how fast the car actually is for a 4000lb car.....
http://www.youtube.com/watch?v=ers3hZTo-qM
quik01ss
01-13-2012, 08:21 AM
So much winn in this thread lmfao
stumprrp
01-13-2012, 09:07 AM
With defense to the CTS-V its got about 500 lbs on a GTO lol.
Slowhawk
01-13-2012, 09:10 AM
Mikes car did fine for the size Cam used. Didn't say it was crap. Was pointing towards IF he has mastered the tuning part the much bigger Cam I offer could work better. Not comparable in size. Didn't even mention that it was.
:lol:
Just pointed out the facts. Since I use to work there. Not a dig at all about it.
In the 14000 posts there is a ton of graphs. just look back many years when I thought I had to prove something like you guy's are now. We've tuned many of your cams,heads ect. They work good, never said they didn't. Do you have to get your ass hurt about it?
Replies above. Still trying to figure out what I'm OWNED about?
For some reason it thought I was knocking AI. Not at all, just know how the OP and crew change there setup's more than there underware. Was throwing out options for future.
Slowhawk
01-13-2012, 09:13 AM
Congrats on the win. We all know driving can make a huge difference.
Myself and the OP know all about #'s and dyno's. We both race alot at the track. The Sick Power power curve WILL go faster at the track if the curve is right. Get it?
quik95lt1
01-13-2012, 09:33 AM
GTO is done.......heads and converter are off/out of the LT again.......how do u think i stay ahead of you LS1 ladies at the track? :D
quik95lt1
01-13-2012, 09:34 AM
idk rob mines 4000lbs on the dot lol
Slowhawk
01-13-2012, 10:38 AM
Ha,ha. Can't wait to see the LT1 go next year.
Want to put some $$ against my car for next season? It's only a lonely LS1:angel:
quik95lt1
01-13-2012, 12:41 PM
u staying on motor or you gonna bitch bottle me? figure you got a minimum 5* of valve angle on me i cant see why you'd need a power adder...
quik01ss
01-13-2012, 01:04 PM
Everyone changes setups ...and everyone wants more power. No? Some people like me get bord with shit and gota spend money somewhere ...cars and building them is hobby right lol.....
Don arnt u turboing the red t.a u got now?
Slowhawk
01-13-2012, 02:01 PM
All I'll say is it has a parachute and will probly need it.:angel: And yes it will still be a street car, probly drive better than it did before.
stumprrp
01-13-2012, 02:07 PM
I still have a slow heavy LT1
BLKHAWK1
:pics:
Still a C5R headed 4xx?
quik01ss
01-13-2012, 02:29 PM
Twin turbos!!!!
Detoxx03
01-13-2012, 02:48 PM
Nice torque
quik95lt1
01-13-2012, 03:52 PM
yea i know ur going TT'd.......its good you are too........... id be embarassed if i had some kid with a NA LT1 breathing down my neck with my C5R headed LSx :D when you want to compare apples to apples ill be glad to run for $$ :D
Slowhawk
01-13-2012, 04:20 PM
Had a usedC5R block, not the heads,used heads ect.. Don't worry we still remember when that C5R blocked,93 octain,A4, 3750lb car was knocking out lower numbers than that solid roller LTX was.:poke:
It's a single being built for some X275 racing.
What happened to run what you brung?
quik95lt1
01-13-2012, 06:06 PM
what did that car best on motor with your 15* heads?
Slowhawk
01-14-2012, 08:06 AM
10.2 at 131 , 85 degree day at full weight of 3780 since the a was back in. Made some good. Changes but sold the car before running in the fall.
evangto87
01-14-2012, 09:28 AM
All i have is one question... who wants to race a bone stock NA 5.0? JK lol. Ill tell you after reading this whole thing... im happy i have a stock car again and the competition aspect of cars is gone in my life.
Slowhawk
01-14-2012, 10:57 AM
Umm, ya, right. I'm sure you've already been doing the roll racing.
Advanced Induction
01-28-2012, 12:11 PM
:lol: You specifically said that your camshaft would not only make more power, but make another 60-70rwhp than the cam Mike is currently running. In other words, gain approximately twice what the typical HR grind does over stock. Unless you have zero real world experience, then I would presume you know that is outside the realm of possibility, which leaves but one explanation. If your marketing strategy is reliant upon the ignorance of your audience, then might I suggest limiting it to your own threads. That would ensure the rest of us have no incentive to call you on bullshit claims. :)
Take Care,
-Phil
