Ls2 braking down under boost
Old 01-04-2012, 07:42 PM
Hixi's Avatar
Default Ls2 braking down under boost
Hi guys just a quick question on a ls2 that's in a Holden commodore
The car has a magnacharger mp1900 with 10psi pully and obviously bigger injectors coils exhaust etc, but after changing the pulley I've noticed it's started braking down under boost , would it be a plug issue or is it leaning out
No codes has come up and I would have thought that the exaust sensors wouldn't let it lean out but I'm still unsure
Old 01-04-2012, 07:44 PM
JPH
JPH's Avatar
Get with your tuner and have him log it? Could be a spark issue?
Old 01-04-2012, 07:55 PM
Hixi's Avatar
Il do that Im just scared of driving it if it may lean out and do
Damage
Old 01-04-2012, 08:01 PM
JPH
JPH's Avatar
Damage
DON'T beat on it until the fuel curve, psi and /spark tables, plugs ALL can be verified.
Old 01-09-2012, 12:21 AM
CAMSTER's Avatar
Default another gauge
All boosted apps should ideally, be monitored by an air fuel ratio meter, especially, when you like to change things around, like pulleys, just so you know what's doing what. When you have it, you'll wonder no more, except, why you didn't get it before...AEM 30-4100 is the best i ever used.
Old 01-10-2012, 08:45 AM
TurboBuick6's Avatar
What CAMSTER said. If I had to take a guess your going lean. Lean on an FI = lots of trouble.
Quick Reply: Ls2 braking down under boost
