I'll be darned... starter doesn't fit. What starter to use???
Old 01-04-2012, 08:37 PM
QwkTrip's Avatar
Default I'll be darned... starter doesn't fit. What starter to use???
I have a Gen IV 6.0L block and a T56 from an F body. I ordered up an F body high torque gear reduction starter and it doesn't even come close to fitting. The solenoid is directly above motor and fouls with the crank sensor and who knows what else if you were able to keep going up.
I figured an F body starter would fit any LS block. It doesn't. So what starter does fit this block with my F body flywheel?
Old 01-05-2012, 12:44 AM
garys 68's Avatar
I assume you've got a truck block, if so get the truck starter
I'm running an iron block 6.0, truck starter, f body LS1 flywheel. Mo problems.
Old 01-05-2012, 05:33 AM
Unertl42's Avatar
what brand is the starter? The AC Delco starter for the truck and ls1 f-body are the same size, just different bolts, ie one uses two long, the other one long one short bolt. I was going to get a high tq starter, but read reviews on here that people had issues with them fitting.
Old 01-05-2012, 06:15 AM
ramairws6's Avatar
Did you try clocking the body of the starter??
Old 01-05-2012, 09:08 AM
1lejohn's Avatar
Exactly. Most aftermarket starters can be adjusted or clocked. I went with a powermaster it fits no problem.
Old 01-06-2012, 06:56 PM
QwkTrip's Avatar
Man, it's hard to be stupid. Gosh, of all people I should have known that!
Maybe the starter fits with 4th gen headers but my headers for 3rd gen will not let it fit. I had to mount starter upside down. That means I'll have to disassemble the starter and drill new drain tubes in the housings. Not sure if it will clear my tubular K-member but it might.
I'll bet a factory starter fits. Problem is I don't want a Delco Remy starter because they make total crap. Any factory starters that are not Delco Remy?
Old 06-05-2016, 03:06 PM
Dave Plummer's Avatar
This is an old thread, but I'm hitting the same problem.
I'm installing an LS3 eRod in a '69 Camaro. Believing the motor to be essentially the same as the 2010 Camaro, I ordered the starter for a 2010 Camaro.
It doesn't clear; it runs into the crank position sensor right above it.
You can't clock or rotate this one in any way, it's all cast.
Does anyone know what starter WILL clear the LS3's sensors and bolt into place? I could try a truck starter, but it's not a truck motor, so that's just a guess. Since I already have to eat this starter (too late to return) I'd rather get it right the next time!
Old 06-05-2016, 05:46 PM
RixTrix's Avatar
I got a MSD starter for my LS3.
I think it was a Power Master XS
Old 06-06-2016, 07:16 AM
joyridin''s Avatar
I used a Summit Racing Mini Starter. Worked fine on my LS3 crate engine. I had problems fitting a starter between the frame and engine. This starter worked well and didn't hit anything.
http://www.summitracing.com/parts/SUM-829400
They have another version, but it is not a mini starter for like $5 less. Not sure how that one fits, but this starter is a good deal for the price.
Old 06-07-2016, 07:04 AM
DietCoke's Avatar
powermaster tucks up real nice.
Old 06-07-2016, 07:17 PM
Michael Yount's Avatar
Just got through installing a TCI starter in my LS3 swap. It's clockable -- with Mast oil pan, I can rotate the solenoid down completely out of the way of the crank sensor/harness. Using Speedway cast stainless manifolds -- manifold and headpipe clear starter easily. Here's a couple of shots....
Quick Reply: I'll be darned... starter doesn't fit. What starter to use???
