are 20 mile on the clock LME cylinder walls supposed to look like this?
Old 01-04-2012, 09:07 PM
IKnowtheFuture's Avatar
Default are 20 mile on the clock LME cylinder walls supposed to look like this?
I'm going to take a wide guess and say no.
It's a lq9 forged with wisecos, lunati rods, and eagle crank. I bought it off of altrdta with 20 miles on it and just got around to start installing it. It hasn't left the engine stand since I took delivery.
Attached Thumbnails are 20 mile on the clock LME cylinder walls supposed to look like this?-c360_2012-01-04-22-06-10.jpg   are 20 mile on the clock LME cylinder walls supposed to look like this?-c360_2012-01-04-21-55-44_org.jpg
Old 01-04-2012, 09:23 PM
gMAG's Avatar
The walls should only have cross-hatch hone marks.
It almost looks like a ring failure, and then someone changed the rings afterward.
I'm no expert, but something is amiss.
Old 01-04-2012, 09:25 PM
97badass's Avatar
Looks like it has been turned over by hand a few times with not very much oil on the cyl walls...
Old 01-04-2012, 09:34 PM
I cant see that kind of scoring from turning over by hand, unless someone degreased the walls IMO
Old 01-04-2012, 09:37 PM
midevil1's Avatar
looks like clearance issue's too me. All of the holes look like that?
Old 01-04-2012, 09:46 PM
97badass's Avatar
^ my thoughts as well, ring gap too tight
Old 01-04-2012, 09:48 PM
from what i can see 1,2,3,6,8 are to varying extents. i cant see the rest as they are too close to bdc
Old 01-04-2012, 09:51 PM
parks450's Avatar
+1 on clearance issues, this is what it looked like when mine were not right:
looks like your pistons are "rubbing" to me...
Old 01-04-2012, 10:44 PM
anyone have an opinion on whats going to happen if I run this? I don't have the funds to do a complete tear down just to see if my pistons are scored badly. the scoring is very shallow, i couldn't feel it when I tried to feel for grooves.
the pistons do have lateral gas ports, does anyone think lme didnt take into account the gas ports when gapping the rings?
Old 01-04-2012, 10:49 PM
parks450's Avatar
premature wear, oil burning etc.
Old 01-04-2012, 11:01 PM
technicalninja's Avatar
Your doomed in my book....
The second picture doesn't look good IMO. If that was an engine I built I'd be pulling it back apart to see what is what. Might not be a big deal but if something IS wrong now is the time to fix. Head gaskets and bolts are what it will cost you now to verify...
But, by posting your concerns and then deciding to forge ahead you will be insulting Mr. Murphy! Never a good idea to cross Murphy...
Gas ports (done properly) should not effect ring fit in bore or piston. It should not create the marks you have.
Have you contacted the folks who put this together? I'd want their opinion before doing anything.
Per your user name you SHOULD have better information regarding the outcome than anyone else. (JK-sorry couldn't resist!)
Old 01-04-2012, 11:09 PM
wantsum410's Avatar
NO WAY I would NOT run it ! I have tore down 2 mtrs from salvage pullouts in the last 3 mo. 1 was supposed to have 77k the other 84k .
We honed all cylinders with no issues & did alot of hand turining fitment check ect & this is not normal .
Old 01-05-2012, 07:15 AM
KCS
Moderator
KCS's Avatar
If you run it like it is now, you may end up damaging the engine further making more expensive to fix than it is now.
Call Bryan at LME and explain the problem. I'm sure they will be more than willing to help you out.
Old 01-05-2012, 07:59 AM
crashinaz's Avatar
Not normal. Didn't happen by turning it over by hand unless there was debris. Obviously a clearance issue if the scoring is in the same location on each hole. Time to pull the worst one, inspect/measure the piston/rings and take a few measurements of the cylinder with a dial bore gauge. You'll be speculating until then. Fresh motor? Figure it out now.
Old 01-05-2012, 03:35 PM
I talked with bryan at lme and sent him the pic. he said the motor should be good to go and the light scoring is pretty common on ls motors. I have never heard that scoring is common on these motors, but then again I haven't built a thousand of these.
Old 01-05-2012, 06:13 PM
TermnEatr's Avatar
Was it supposed to be like this when u bought or did u get ripped off?
Old 01-05-2012, 07:17 PM
ls1 1990 VN's Avatar
Looks like it's been over fueling & washing the bores
Old 01-05-2012, 11:10 PM
I bought if off altrdta and he even signed a piece something that said there were no problems with the motor, he just wanted a larger ci motor and bigger turbos.
Old 01-06-2012, 12:37 AM
It looks so similar to an engine I had built, 15k later with no end of problems trying to get it to run properly, I had it stripped by a different shop, the rods had been installed wrong, the bearings looked like a 500k trashed engine, cam was trashed, 4 bores oval etc etc. You need to strip it & have a real good look.
This not to say in any way this has happened to yours though, but you have a major issue, sorry man.
