Dynamometer Results & Comparisons - CMS C6 z06 E85 Results
Ryne @ CMS
01-04-2012, 11:08 PM
Well we have been toying around with the idea of putting my 08 C6Z on E85. After doing some extensive research on not only E85 but the C6Z's fuel system we started by dissecting a $350 plus fuel pump assembly to figure out exactly what we had to work with in the tank and if we would need more pump. After we had decided on our fuel pump setup we contact Jon at Fuel Injector Connection to pick up a set of his in house built LS2 bodied 1000CC Billet tipped injectors. In order to ensure we wouldn't have fuel pressure loss up top we installed a MSD Fuel Pump Booster. We went with this unit because it has a computer interface that allowes us to actually plot out the fuel pump voltage v. engine air flow as opposed to just an on off switch like other units. After minor tuning the car was running great. There is no sacrifice in drivability what so ever. After the part throttle tuning was complete we strapped it to the dyno to see what she was putting down. By the end of tuning we were all very impressed with the results. The power carried out further than it had previously and the car put down 641.3hp and 576.4tq.
To those of you that don't know the car this is just a simple setup on a stock un-touched bottom end. The car is equiped with a custom CMS cam, Richard at WCCH stage 2 ported heads with competition valve job and SS exhaust valves, Kooks 1 7/8 headers with custom exhaust, cometic .040 head gaskets, in house ported FAST 102 with NW 102 throttle body and Halltech 107R intake.
http://i294.photobucket.com/albums/mm82/cmswork/myz06e85tq.jpg
http://i294.photobucket.com/albums/mm82/cmswork/myz06e85af.jpg
Pwebbz28
01-05-2012, 01:31 AM
I bet that thing is nuts!! What were the numbers before E85?
venom ws7
01-05-2012, 05:17 AM
Damn nasty numbers Ryne Congrats and great work.
What's the compression?
Ryne @ CMS
01-05-2012, 09:10 AM
last week it put down 608 rwhp 540 rwtq.... i am loving the tq from the e85!
roughly 12:1
racerfox
01-05-2012, 01:26 PM
where you running 91? or race gas before e85?
Ryne @ CMS
01-05-2012, 04:39 PM
91+ two cans of torco, or 100 mixed with 91........... not a daily driver however
navyblueSS
01-05-2012, 06:02 PM
Nice results!
juniorz28
01-05-2012, 09:48 PM
Nice results Ryne..
Sommer86
01-05-2012, 09:58 PM
WOW, nice and congrats!! Can't wait for you to get your hands on my car, lol. :)
Tireburnin
01-06-2012, 10:30 AM
Great results! How much did you end up changing the timing between the tunes for the fuel change (before/after E85)?
stumprrp
01-06-2012, 10:32 AM
that car must be a damn riot, 9 sec ride with a good hook
Ryne @ CMS
01-07-2012, 04:09 PM
on the 91 octane 19-20 degrees max, 91+two cans of torco 24 degrees, e85 27 degrees, i could put more in but it didnt make anymore more power, but i running the e85 at a leaner lambda as well .85 versus .83...
Pwebbz28
01-07-2012, 04:17 PM
Were the 95lb injectors mandatory for that amount of power on E?
T.Man
01-07-2012, 04:19 PM
Killer results! Have you tried going leaner than .85?
Ryne @ CMS
01-08-2012, 02:41 AM
no, i could probably get by with a 65 lber, but i said why not run these, i really like this particular injector
adamantium
01-08-2012, 12:35 PM
Hows the gas mileage? I always hear people getting shitty mileage because there damn tuner does nothing for there part throttle/cruising afr.
Pwebbz28
01-08-2012, 12:42 PM
Mileage depends on how lazy the tuner is to be honest. Cursing mileage for a few is unchanged and for some with a good tune still lose close to 20%
Tireburnin
01-09-2012, 08:40 AM
Good to know. Running it at .85 is interesting too.
Impressive results.
Ryne @ CMS
01-10-2012, 12:33 PM
Impressive results.
another combination might pickup from a leaner mixture, mine didnt so why run it that way.... even on gas from my experience ls7's generally dont react that great to lean mixtures, but that has only been my experience
Ryne @ CMS
01-10-2012, 12:34 PM
i normally get about 24ish on the freeway in sixth , i getting about 17-18 right now... i might be able to get that number higher but i havent had much time to mess with it
jimbob
01-10-2012, 01:49 PM
i normally get about 24ish on the freeway in sixth , i getting about 17-18 right now... i might be able to get that number higher but i havent had much time to mess with itNice gain with the switch..
I'm trying 45 degrees timing, instead of 32, at part throttle (on E-85), hopefully, I'll get a milleage bump. What are your thoughts on this much timing?
Ryne @ CMS
01-10-2012, 05:25 PM
i dont think it will help that much.... 45 degrees at what rpm? i have decent size cam if i throw that much timing low in the rpm with buck pretty good... i cruising at 40 degrees above 1800 right now
jimbob
01-10-2012, 08:04 PM
i dont think it will help that much.... 45 degrees at what rpm? i have decent size cam if i throw that much timing low in the rpm with buck pretty good... i cruising at 40 degrees above 1800 right nowCruise rpm, similar to your 1800 rpm, actually more like 2200 for 60mph now. Sounds doable..
Detoxx03
01-13-2012, 01:42 PM
That's killer.
