z28dan
03-16-2004, 04:05 PM
Fellas, I'm a bit worried about screwing up the install of my new Moser 12 bolt (3.73, POSI, 33 spline, TC/ABS). Here's what I plan on doing, and I want to be sure that this is right!!!
1. Remove old rear end, pull out axles
2. press off the exciter rings from old axles (is this a problem? should i be ready for buying new ones? I'm going to a Napa to do it...)
3. take off the caliper bracket (haven't seen it yet, but the moser directions talk about it)
4. on the new axles - put on the caliper bracket, press on the exciter rings. (I read that you have to 'line up' something. What needs lining up? The cliper bracket?)
5. press on the bearing.
That's about it (besides hooking up the sway bar to the new rear end).
Anything wrong with the above? is there a good step through somewhere?
I dont want the rearend doing this: :bomb:
thanks!
-Dan
thanks!
-Dan
