Truck manifold wastegate sources
Old 01-05-2012, 10:23 AM
littlereds10's Avatar
Default Truck manifold wastegate sources
Wrapping up my turbo 4.8 build and I'm just trying to figure out the best places to get the wastegate and bov vacuum/pressure sources. My main question is, is it safe to T off the line that goes from the top of the throttle body to the passenger side valve cover for the wastegate?
Is it also ok to T off the line that goes from the top of the intake to the back of the driver side valve cover?
If there are better places for these sources, let me know. I already have my electronic boost controller pressure sensor and boost gauge running off that port about 3/4 of the way back on the passenger side of the intake that you can cut off for a pressure/vacuum source.
Any advice will be appreciated
Old 01-05-2012, 10:42 AM
dville_gt's Avatar
No, this line is for pulling air out of the crankcase. If you are running a turbo you can't have this line going from the t/b to the passenger valve cover any way since you'd be boosting into the crank case.
Again, this is for the PCV system. You are going to have to get a catch can or breathers and block off the stock PCV setup.
I run a vacuum manifold, (northern tool has one for like $10) that has 7 1/4npt ports on the front and a 3/8th npt port on the back. You connect the 3/8th to the line that goes from the intake to the brake booster and then connect all of your vacuum lines to the manifold.
Old 01-05-2012, 12:11 PM
Thanks for that info! How did you go about blocking your PVC setup?
Old 01-05-2012, 12:30 PM
Can I block the pcv system then just run the line from the top of the TB to my wastegate..etc?
Old 01-05-2012, 01:08 PM
dville_gt's Avatar
You will need to setup a vented catch can or a sealed catch can with a check valve if you want to retain PCV function.
Old 01-05-2012, 01:33 PM
boss79z's Avatar
http://www.northerntool.com/shop/too...ct_13795_13795
Would this work as a good manifold vacuum?
boss79z's Avatar
jeeze....vacuum manifold*
Old 01-05-2012, 04:09 PM
dville_gt's Avatar
That is the one I use. I sand blasted off the color and painted it black.
Old 01-05-2012, 06:31 PM
Ryans99ls1's Avatar
reference the vacuum manifold from the brake booster line.
Old 01-05-2012, 09:59 PM
boss79z's Avatar
Cool. I will be sanding it down also.
Quick Reply: Truck manifold wastegate sources
