I might be buying some heads....
are these the right ones to buy for an ls1???
getting them from a friend....set has been ported and polished...valves included.
I'm getting them with no springs or retainers....but I alredy have those....
I have a 2000 ls1
I have a 2000 ls1
Here is a list of a few casting #'s:
853 97-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
706 Heads
As The List Above Mentioned You Have The 5.3 Heads.stock They Have The Same Intake And Exhaust Port As An Ls1 Head They Just Have A 1.89" Intake Valve Whereas The Ls1 Has A 2.00.these Heads Are Used To Bump Up The Compression Without Milling.i Have The 862 Casting.
Originally Posted by soundengineer
So I should be ok with just slapping them on If I buy them???
what kind of compression ratio should I expect?
and will the smaller intake valve hurt me any??? or should I make sure there is a 2.00 intake valve in it??
so will I need a different length pushrod with these heads???
and will I have PtV clearance issues with my X1 cam??
and If it has the smaller valves in it...should I take it to a local machine shop, have them make it fit a 2.0 valve...and buy some valves to fit??
If the heads are unmilled then there should be no issue with PtV clearance.
