Wiring.. Progressive controller+LNC-2000+FPSS
Old 01-05-2012, 04:44 PM
FIREHAWK #07's Avatar
Default Wiring.. Progressive controller+LNC-2000+FPSS
Wiring up a 2011 Camaro with a Nitrous Outlet plate system to include a NOS mini progressive controller + LNC-2000 to retard timing + Fuel Pressure Safety Switch + bottle heater + purge.
Any diagrams available?
Old 01-08-2012, 10:45 PM
DopeFedZ's Avatar
If it blows it's not my fault...
Old 08-16-2014, 09:42 AM
SumtinCoo's Avatar
The above diagram is right except on the fpss relay the positive side of the solenoids needs to be on the 87a pin. So you need a 5 pin relay for that one. 87a is in the middle. I found out this the hard way and couldn't figure out why my motor wasn't spraying. You want the power to pass through the relay at all times, so you want it to be normally closed, then when the fpss opens up it will ground the relay and open the circuit. Hopefully this helps anyone else that needs this diagram.
Old 08-19-2014, 04:01 PM
brandon@nitrousoutlet's Avatar
I have the exact diagram you need. Feel free to PM me your email address and I can send it over. (not that the one above is wrong or anything)
Quick Reply: Wiring.. Progressive controller+LNC-2000+FPSS
