Dynamometer Results & Comparisons - Vengeance built Twin Turbo C6 Z06 goes 1343/1229... Graph/Video/Info Inside
Ron@Vengeance
01-06-2012, 01:26 PM
This project actually started October of 2010.. The build has snow balled quite a bit since then...
For more information on how this all started out click here:
http://ls1tech.com/forums/multimedia-exchange/1341381-vengeance-racing-tim-lynchs-twin-turbo-c6-z06-build-thread.html
After putting some miles on the combo in the link above Tim decided he wanted to build an engine that could support larger boost levels... The new engine consisted of the following:
427 cubic inch RHS
RHS Race Block- 4.125 Bore/Standard Deck
Lunati Pro 4" Stroke Crankshaft
Lentz Connecting Rods
Diamond Pistons/Rings
Custom Camshaft- MILD solid Roller
Jesel Solid Lifters
All Pro LSW-1 Cylinder Heads
Jesel Rockers
Intake
FAST LSXR 102mm Intake
Nick Williams 102mm DBW Throttlebody
Fuel
Racing Solutions Triple Intank Fuel System
FIC 1500cc Hi Impedance Fuel Injectors
Clutch:
RPS Triple Carbon
Tick Adjustable Master Cylinder
Exhaust:
B&B Fusion
DMH Dual Electric Cutouts
(At anything over 19psi we had extreme backpressure issues that were solved by adding the cutouts)
Boost Controller:
AMS 1000
Turbos:
Precision 62mm Billet Wheel
Modified APS kit
Fuel:
93 Octane up to 15psi
VP Q16 up to 25psi
Dyno Graph:
http://i88.photobucket.com/albums/k176/VengeanceRacing/TimOverlay.jpg
Run #13 had a much more aggressive "ramp" that would have allowed us to make a bit more power if we were able to keep the tires from spinning...
Run #12- we softened the ramp a bit to allow the boost to come on more gradual to get a clean pull..
Video Clip
Includes Pics/Idle/Dyno Pull/Dyno Sheet
http://www.youtube.com/watch?v=8wSFTjaGuYs
This Z06 will average 34mpg cruising @ 80mph on the highway and drives about as close to stock as you can possibly get with the modifications it has.
Stay tuned for good WOT videos coming shortly!!!
Gabbiani
01-06-2012, 01:32 PM
mother of god......
Guessing 900 to 1k even on 15psi. Depends on how much timing they had to pull out too.
Curious if it is usable.
MikeG
01-06-2012, 02:55 PM
Nasteeeeee
What did it make on the 93 at 15psi?
madmax4499
01-06-2012, 03:14 PM
Very nice!
black00TA
01-08-2012, 10:06 AM
wtf...that's earth shattering. you guys rock!
Imstock2
01-08-2012, 10:23 AM
good low-mid 8's car if you can get her to hook... an 8 sec car getting 35 mpg at 80 mph... only in a vette :). I love when import guys say.... well mine gets 30+ mpg and I'm like yea I get 34ish cruising at 70 how about you?
ss2000
01-08-2012, 10:42 AM
Wow! You guys do some fantastic builds down there.
LIL SS
01-08-2012, 12:13 PM
Dual 62's making over 1300rwhp? Wow!!!
amwellls1
01-08-2012, 06:17 PM
Nice, that thing is wicked
bigpapi211
01-08-2012, 07:59 PM
put me on the order form for one of these
itsslow98
01-10-2012, 02:44 AM
Id love to see that car go low 8s with a 6 speed.:bomb:
slowride
01-10-2012, 08:12 PM
Are the turbos 6265's?
venom_03
01-11-2012, 11:48 AM
:drool:
That is just down right nasty!
evolve
01-11-2012, 11:51 AM
I think when you guys hit the gas you may break the time-space continuum and travel backwards in time! JK, awesome build and it will be unstoppable on the street!
