tr224 cam question please help
i have a tr cam 224/224 @.050 114lsa .566/.566 lift i need to know what springs and push rods to buy everybody tells me different things the car has stock 242 heads thank you!!
I assume you meant 241 heads on an LS1. A simple single beehive design spring will do fine. People have had some trouble out of the comp 918's springs but I used them with no issues. And some chromoly 7.4'' pushrods are what you need. You can get both from Texas-speed.com You dont need dual springs but if you plan on going bigger with a cam in the near future, might not be a bad idea. It would be overkill at this point to use dual springs on such a mild cam but some will argue this.
