New LS1 Owners - Newbie Tech - What manifolds are these?
View Full Version : What manifolds are these?
1bigoldman
01-07-2012, 10:20 AM
I saw these on eBay. They look like they would fit fairly tight. What car would these have come off of?:confused:
http://www.ebay.com/itm/LS1-Swap-Stainless-Steel-Exhaust-Header-Manifolds-Camaro-Turbo-LS2-LS6-/320823063318#ht_500wt_927
RPM WS6
01-07-2012, 10:53 AM
Those look like stock '98-'99 LS1 F-body manifolds. They were stainless in those years, then in 2000 the design was updated and the material was switched to iron.
LeanPocket
01-07-2012, 11:35 AM
one of them looks like a truck manifold and the other is a 98-99 manifold.
Starz T/A 17
01-07-2012, 07:07 PM
Wouldn't they be from a 01 or 02. I don't see an EGR hookup and I thought that 98-99's manifolds came with EGR
RPM WS6
01-07-2012, 07:21 PM
Nope. '00+ looked different, and were iron.
The EGR connection point on the '98-'99 isn't molded into the manifold the same way that it was for '00 (and '01-'02, except those just had the provision with no hole drilled since they didn't use EGR).
In the link above, the manifold that looks like a big log is the passenger side manifold, and there is a tube that runs out from the main body of the "log"....that tube is for EGR. The AIR connection is on top of the #2 primary.
wildcamaro
01-07-2012, 10:31 PM
That top one is def a 98-99 fbody, i have a 98 and wish i had kept the manifolds from bc now i am looking for one to fit my 81 camaro l33 swap...doh
