What does the PCM use when the throttle position sensor is unplugged?
Old 01-07-2012, 04:45 PM
TXjeepTJ's Avatar
Default What does the PCM use when the throttle position sensor is unplugged?
I have a issue with a 5.3 where when it is revved w/ the pedal (forcing IAC open to raise the RPM using the hp tuners scanner doesn't create any problems, it only runs weird when raising RPMs w/ the pedal)
When I unplug the TPS, it runs very good, like as it should. Reving w/ the pedal everything is nice and smooth *when TPS is unplugged*
So, what does the PCM fall back on when the TPS is unplugged?
I suspect something is messed up w/ the tuning in that area, with a table that utilizes the TPS sensor to run the engine
(I've replaced TPS sensor, and it is showing normal values using HP tuners scanner)
Old 01-07-2012, 05:14 PM
Anthony Williams's Avatar
Limp home mode = limited engine speed and trans shifting. The pcm will try and read engine needs from the other sensor=MAF,MAP,O2, Crank position,O2, trans speed etc. it will run but your gas milage will plummit.
