Pushing water damage?
My motor seemed to be pushing water so I pulled the heads today to put in some arp studs and cometic gaskets.
The drivers side had shiney areas at the tops of the pistons and head. But the passenger side had the same clean areas but it is no longer smooth its almost like a sandblasted finish but not as bad. Is this from the water or something else? The plugs showed no signs of detonation.
