Sponsored by: DashLynx
Undercoating
Old 01-07-2012, 07:58 PM
lees02WS6's Avatar
Default Undercoating
POR-15 is a popular choice, but decided try rust bullet automotive paint.
Before:
After:
I'm pretty pleased with the result. I'm going to paint the "frame rails" in Por-15 though.
Old 01-07-2012, 08:02 PM
lees02WS6's Avatar
I did prep the surfaces by sanding everything down with an orbital sander where possible, and by hand where the sander couldn't be used.
Old 01-07-2012, 08:03 PM
02ws.sik's Avatar
Very nice! How long did that take you?
Old 01-07-2012, 08:09 PM
lees02WS6's Avatar
3 days, I took my time sanding and masking. I did not use my spray gun, just brushed it on.
Old 01-08-2012, 10:50 AM
Brian2001SS's Avatar
Nice work. What did you have to do to disconnect all the lines to the fuel tank to drop it?
Old 01-08-2012, 01:02 PM
lees02WS6's Avatar
I released the pressure using the schrader valve on the fuel rail. Then I disconnected all the fuel lines, and plugged them up using vacuum caps. Thanks for the compliment.
Old 02-12-2012, 07:47 PM
lees02WS6's Avatar
Got everything back in. Too much silver??
Old 02-12-2012, 08:24 PM
badbird5.7's Avatar
not to much silver at all, that looks killer!
stevesfbody's Avatar
Looks immaculate!
Old 02-13-2012, 10:24 AM
Copy & Paste Moderator
VIP1's Avatar
What car is this? My first thought was f-body (that looks like the bottom of the trunk), but I see an IRS.
Old 02-13-2012, 10:35 AM
lethal bird's Avatar
That's an fbody you can see the rear seat holes.
Old 02-13-2012, 10:37 AM
MasterV8's Avatar
Fbody but not fbody rear.
Old 02-13-2012, 11:23 AM
lees02WS6's Avatar
Correct, it's a 4th gen f-body, but a c4 rear suspension.
Old 02-13-2012, 12:13 PM
HotWhipT/A's Avatar
I've never seen that done before. Got a write up, some more info, pictures? How does it drive?
The guy that own zeus performance has the same setup in his SOM lt1 firebird.
Old 02-13-2012, 12:20 PM
lees02WS6's Avatar
There is an IRS thread in the suspension section from August 2011. It rides firm, it's still a lowered car with 11" wide wheels on the rear, but is far less jittery over road imperfections.
That is correct also, he was probably the first to put one on a 4th gen - at least first documented install any way, Orange_99_SS also has one.
Old 02-13-2012, 12:59 PM
VIP1's Avatar
I thought it looked familiar.
Nice Work.
Old 02-13-2012, 01:37 PM
HotWhipT/A's Avatar
I think I found it in case anyone else wanted to see it.
https://ls1tech.com/forums/suspensio...s-4th-gen.html
Old 02-13-2012, 03:25 PM
Formally Simplɘ Jack
BoricuaHec01's Avatar
Wow, that's amazing work, good stuff OP.
Quick Reply: Undercoating
