Need to quiet it down
I have LT's with y, high flow cats, magnaflow muffler, heads, cam, and 3600 stall. What is the cheapest way to quiet this down a little by losing the least amount of hp? I know I will lose some, but since this build/stall went in this thing is friggen rediculous.
You can install a Magnaflow #14419, 4" dia,14" case L muffler in the I-pipe without any clearance issues at all. If you're willing to massage the under carriage on the passenger side of where the I-pipe fits the you can install a Magnaflow#12867, 5" dia.. 14" case L muffler in the I-pipe.
The #14419(about $80) will clearly help, but the #12867(about $95) will help quite a bit more.
FYI, you could also install a #14419 before each exhaust tip.
You shouldn't lose any power with any of these options, since there straight though mufflers.
