Dynamometer Results & Comparisons - WTF very weird Dyno results!!! Confused!
GoBabyvroommm
01-08-2012, 01:11 AM
Just going to give you a lil info on the car. 98 Formula 88k has pace setter LTs, off road y pipe to a 3 1/2 inch Borla str8 through muffler that ends behind the pass. seat. Has a that big 90mm lid,bello, stock Tbody with a c5 ZO mas. Has a LS1 intake egr delete. It has a 3500 tci nitrous stall on manual valve body built 4L60E. Stock rear end 342 gear. Car was a 6speed car.
I got the car tuned at speed inc after i fixed the exhaust and change the intake set up. The car without a tune put down 281 with a 11.1 a/f ratio after the tune 293 with a 12.5 a/f ratio.
Anyone have any idea's wtf is going on here? The car runs strong.
http://img69.imageshack.us/img69/421/img00098201201071553.jpg
black00TA
01-08-2012, 09:55 AM
what did speed inc. have to say about it? there are to many variables at this point to even begin trying to diagnose..
WKMCD
01-08-2012, 02:10 PM
Probably just their tach pickup on the fritz.
35thsscamaro02
01-08-2012, 02:47 PM
Hmmm weird indeed
GoBabyvroommm
01-08-2012, 03:20 PM
Well they said start with the spark plugs, coils, then compression test. My friend also said maybe the fly wheel can be messed up. This use to be a m6 car so who knows maybe they fab'd the 6speed fly wheel. A lot of stuff on the car was done pretty ghetto/cheap but not by me. At 80mph car feels like its going to fall apart, massive shaking/vibrating. Like every Fbody with a stock rear end mine makes noise b. But after the dyno I can see a fly wheel that is doing this doing this.
If it was something with the motor i don't think it would have ran as well as it did. I wish the track was open so I can see what it does know. Hell if it did like a 12.3/2 I would be amazed.
BTW tech is fine other than being off very little, which is normal for these cars.
